I've tried everything to fix the error E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?.
I've tried cleaning the apt-get system, using install -f, obviously using fix-missing and update or upgrade.
The output of my sudo apt-get install qtbase5-dev:
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/pool/main/q/qtbase-   opensource-src/libqt5xml5_5.5.1+dfsg-16ubuntu7.5_amd64.deb  404  Not Found [IP: 50.7.82.37 80]
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/pool/main/q/qtbase-opensource-src/qtbase5-dev-tools_5.5.1+dfsg-16ubuntu7.5_amd64.deb  404  Not Found [IP: 50.7.82.37 80]
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/pool/main/q/qtbase-opensource-src/qtbase5-dev_5.5.1+dfsg-16ubuntu7.5_amd64.deb  404  Not Found [IP: 50.7.82.37 80]
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/pool/main/q/qtbase-opensource-src/libqt5opengl5-dev_5.5.1+dfsg-16ubuntu7.5_amd64.deb  404  Not Found [IP: 50.7.82.37 80]
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/pool/main/q/qtbase-opensource-src/libqt5sql5-sqlite_5.5.1+dfsg-16ubuntu7.5_amd64.deb  404  Not Found [IP: 50.7.82.37 80]
The output of update:
Fetched 109 kB in 3s (34,9 kB/s)
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://linux.teamviewer.com/deb stable InRelease' doesn't support architecture 'arm64'
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages  404  Not Found [IP: 50.7.82.35 80]
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages  404  Not Found [IP: 50.7.82.35 80]
E: Failed to fetch http://es.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages  404  Not Found [IP: 50.7.82.35 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.26 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I have tried everything I've seen on other questions and other forums but I really don't know how to solve it.
Do you have any idea?
Thank you in advance!
EDIT
Added some terminal outputs
~: dpkg --print-architecture
amd64
And
~: dpkg --print-foreign-architectures
i386
arm64
cluna
sudo dpkg  --remove-architecture arm64
If you have crosscompile tools on your System you will get an error similiar like
Architektur »arm64«, is in use, can not be removed
an overview gives
dpkg -l | awk '/:arm64/{ print $2 }'
If so you can remove them with sudo apt-get purge $(dpkg -l | awk '/:arm64/{ print $2 }') and remove the architecture sudo dpkg --remove-architecture arm64
nobody
  • 5,792
