18
I know I'm supposed to have the Startup Disk Creator installed in the Ubuntu 19.04 version, but I ran the
apt policy usb-creator-gtk
And got
usb-creator-gtk:
  Installed: (none)
  Candidate: 0.3.5
  Version table:
     0.3.5 500
        500 http://se.archive.ubuntu.com/ubuntu disco/main amd64 Packages
What I want to do is boot my other PC with a USB stick, I've already installed the Ubuntu 19.04 on the USB stick, but the PC is not detecting it (it is not in FAT16 format, and I can't figure out how to reformat it).
AS95
  • 303
To install the application, run the following commands:
sudo apt update
sudo apt install usb-creator-gtk
Additionally, if you are running KDE or Kubuntu instead of Ubuntu or Ubuntu Gnome, then you should probably use usb-creator-kde instead of usb-creator-gtk:
sudo apt update
sudo apt install usb-creator-kde
Furthermore, if you are using LXQT on Lubuntu, then you probably want to use usb-creator-kde.
mchid
  • 44,904
  • 102
  • 162
