Let's say I have an Ubuntu bionic server that I wish to disable IPv6 on. (Important: This is not an XY Problem, please don't guess at what I'm trying to achieve or ask me why I want to do this. I know how great and wonderful IPv6 is, no need to preach to the choir.) One way to do this is to set the following sysctls:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
When sysctl is run manually with the settings above, this disables all IPv6 networking on the host:
# ip -6 a
Great, but that doesn't persist through a reboot. The recommended way to make sysctls persist is to put them in /etc/sysctl.conf, or a file in /etc/sysctl.d. I did that, but after a reboot, IPv6 is still there:
# ip -6 addr
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 <censored>/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 2591985sec preferred_lft 604785sec
inet6 fe80::250:56ff:feae:c158/64 scope link
valid_lft forever preferred_lft forever
And yet, the sysctls appear to be correctly set:
# sysctl net.ipv6.conf.all.disable_ipv6 net.ipv6.conf.default.disable_ipv6 net.ipv6.conf.lo.disable_ipv6
However when I set them on the command line, to the same value, suddenly IPv6 is actually disabled:
# sysctl -w net.ipv6.conf.all.disable_ipv6=1 net.ipv6.conf.default.disable_ipv6=1 net.ipv6.conf.lo.disable_ipv6=1
# ip -6 addr
So my question, then, is: Why does setting sysctls to specific non-default values in /etc/sysctl.d/ appear to be doing something according to the output of sysctl itself, and yet not actually affecting the kernel's behavior? Is there some subtle difference between setting a sysctl and having it take effect?
I know that sysctl is an interface for /proc/sys but I am seeing the same thing there as well:
# cat /proc/sys/net/ipv6/conf/all/disable_ipv6
# ip -6 a
valid_lft 2591945sec preferred_lft 604745sec
# echo 1 > /proc/sys/net/ipv6/conf/all/disable_ipv6
# ip -6 a
Also, I have done significant research into this, this question is NOT a dupe of any of these:
