i am new to Ubuntu and linux ,can any one help me with the installation of USB wifi adapter drivers on Ubuntu . please see the link below for the adapter description .
https://www.tp-link.com/en/home-networking/adapter/archer-t3u/?utm_medium=select-local
Thank you
Pepe
Download this GitHub file.
Traverse to the download directory then do the following:
Compile using make command
Install using sudo make install
Note : To unload driver you may need to disconnect the device
Then Run the following commands:
cd ~
sudo dkms add ./rtl8822bu
sudo dkms install 8822bu/1.1
Reboot the system for new module to be picked up
P.S.
You might need to install dkms as well, if not already present.
To install dkms type following: sudo apt install dkms
