I downloaded the latest version of hplip (3.19.5) from here. Following the installation instructions, I ran:
sh hplip-3.19.5.run
It all worked well until the last step, where I got the following output:
PRE-BUILD COMMANDS
OK
BUILD AND INSTALL
Running './configure --with-hpppddir=/usr/share/ppd/HP --libdir=/usr/lib --prefix=/usr --enable-qt4 --disable-qt5 --enable-doc-build --disable-cups-ppd-install --disable-foomatic-drv-install --disable-libusb01_build --disable-foomatic-ppd-install --disable-hpijs-install --disable-class-driver --disable-udev_sysfs_rules --disable-policykit --enable-cups-drv-install --enable-hpcups-install --enable-network-build --enable-dbus-build --enable-scan-build --enable-fax-build --enable-apparmor_build'
Please wait, this may take several minutes...
Command completed successfully.
Running 'make clean'
Running 'make'
error: 'make' command failed with status code 2
Indeed, when I run make I get:
make: *** No targets specified and no makefile found. Stop.
