I'm using Xubuntu 18.04 and I have a problem with my network card.
When I boot my PC, I can't use my network card: it doesn't appear in ifconfig. But when I soft reboot, everything goes ok.
In Xubuntu 16.04 I had no problem.
How can I fix this strange behavior?
Here my lspci output:
00:19.0 Ethernet controller: Intel Corporation 82579V Gigabit Network Connection (rev 04)
My lshw when network is down:
  *-network UNCLAIMED
       description: Ethernet controller
       product: 82579V Gigabit Network Connection
  *-network:0
       description: Ethernet interface
       capabilities: ethernet physical
  *-network:1 DISABLED
Any idea? Thank you!
Edit 2019-06-14 15.20:
My lshw when network works:
  *-network
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: eno1
       version: 04
       serial: 00:22:4d:7f:db:ca
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.13-5 ip=10.19.85.167 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:28 memory:f7c00000-f7c1ffff memory:f7c39000-f7c39fff ioport:f080(size=32)
  *-network:0
       physical id: 1
       logical name: virbr0
       serial: 52:54:00:5a:c2:c1
       configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A ip=192.168.122.1 link=no multicast=yes
       physical id: 2
       logical name: virbr0-nic
       configuration: autonegotiation=off broadcast=yes driver=tun driverversion=1.6 duplex=full link=no multicast=yes port=twisted pair speed=10Mbit/s
/etc/network/interfaces is simply:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
And here the output of cat /etc/netplan/*.yaml:
# Let NetworkManager manage all devices on this system
network:
  version: 2
  renderer: NetworkManager
In Ubuntu 18.04 there is a new network configuration tool netplan. Netplan sometimes have some timeing issues.
Try to login and type
sudo netplan apply
and check ifconfig or ip address.
If your network is configured now, then you have this timeing problem. If this is the case then you probably should read this Netplan does not apply at startup
