24
When starting pgAdmin, I'm prompted:
Please set a master password for pgAdmin
This is a new feature of pgAdmin4 4.7: https://www.pgadmin.org/docs/pgadmin4/dev/release_notes_4_7.html
How can I disable this?
The local documentation tells me to set the "configuration parameter" MASTER_PASSWORD_REQUIRED=False, but I don't know where/how to do this: http://127.0.0.1:37059/help/help/master_password.html
Thomas Landauer
  • 831
  • 18
Took me a while to find out, that's why I'm posting it here:
  1. You need to locate a file named config.py. In my case it's at /usr/share/pgadmin4/web/config.py
  2. Now create a file config_local.py (in the same folder) and enter: MASTER_PASSWORD_REQUIRED=False
  3. Restart pgAdmin server.
  4. The prompt should be gone :-)
Some reference about config files: https://www.pgadmin.org/docs/pgadmin4/dev/desktop_deployment.html#configuration
EDIT: It looks like in higher versions (I now have pgAdmin4 4.26) the directory changed to /usr/pgadmin4/web/
Thomas Landauer
  • 831
  • 18
11
For those on windows, the config.py is located under
C:\Program Files\PostgreSQL\12\pgAdmin 4\web
or
C:\Program Files (x86)\pgAdmin 4\v4\web
Create config_local.py inside of that folder
yujinyuz
  • 111
