I've been trying to use Ubuntu's "Disks" program to create images of partitions on my friend's laptop and then restore them without success. I take backups onto an external hard drive, then delete all partitions on the laptop, create empty partitions with the exact number of original bytes and restore the images from the external HDD, but Windows isn't even able to find its own bootloader and so I can't boot.
So now I'm trying something different. She doesn't use Windows anyway, so I'm going to leave the Windows partitions intact, and chose sda7 to install the the Ubuntu 16.04 bootloader.
Now in BIOS I can see a separate Windows bootloader and the Ubuntu grub64 file which I selected as the trusted UEFI file for bootloading. So now she has a dual-boot system.
Now I want to try creating a clone of sda7 (using Ubuntu's "disks" app), so that even if I delete partitions sda7, sda5 and sda6 and then re-create them and restore sda7's clone, I should be able to select the bootloader of sda7 from BIOS as the trusted bootloader and have a dual-boot system as before.
But before doing that, I want to verify if the bootloader is really in sda7. I tried doing grep -r "grub" . from the root folder, but that's probably the wrong thing to look for, so could you help with this? How do I make sure the bootloader is in sda7? Which files are those?
John David
  • 143
The bootloader that is run by your UEFI bios is not loaded from /dev/sda7, but from your EFI partition, /dev/sda2. Your current system has this partition mounted at /boot/efi/. Search this partition as root to find the grub binary and grub cfg file.
This cfg file points grub to your boot partition, and then to another autogenerated cfg file you can see at /boot/grub/grub.cfg. This cfg file contains all the data used to build the grub boot menu and is written when you type "sudo grub-install" from within linux.
Jesse C
  • 28
First, you would rather double check that you are actually booting with EFI and no the old BIOS:
[ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
If you are acutally booting with EFI, the GRUB files are stored:
  • in the ESP partition (in /EFI/ubuntu)
  • in /boot/grub
  • in /etc/grub
so yes /dev/sda7 holds some GRUB files most like the ones in /etc/grub and /boot/grub.
I am not 100% sure about that but if /dev/sda7 is wiped /boot/grub/grub.cfg will be missing and GRUB will not work properly.
solsTiCe
  • 9,515
