I tried this command but it doesn't work
sudo add-apt-repository ppa:leaeasy/dde
it says
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/leaeasy/dde/ubuntu disco Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I also tried changing "disco" to "bionic" in
/etc/apt/sources.list.d/leaeasy-ubuntu-dde-disco.list
but when I try to install it with this
sudo apt-get update
sudo apt-get install dde
it says
Building dependency tree
dde : Depends: dde-desktop but it is not going to be installed
Depends: deepin-wm but it is not going to be installed
I also tried
sudo aptitude install dde
it installs but I am not able to start dde with startdde because the binary is not in the path.
I also don't see any Deepin entry in login menu.
and I tried all answers in Unable to correct problems, you have held broken packages and What can I do if a repository/PPA does not have a Release file? but no luck.
does anyone know how can I install dde?
