I have an Asus monitor for a 2016 XPS 13 developer edition laptop. I've been trying to get the resolution to look better than the defaults. I ran the following xrandr commands:
xrandr --newmode "1920x1080_60.00"  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync
xrandr --addmode DVI-I-1-1 "1920x1080_60.00"
Afterwared I changed the settings in the GUI manager. The screen looks much better but the edges overflow past the monitor edges. Is there a good way to fix this? The monitor I am using is:
https://www.amazon.com/ASUS-MB169B-1920x1080-Portable-Monitor/dp/B00FE690DI/ref=sr_1_3?keywords=portable%2Bmonitor&qid=1560014011&s=gateway&sr=8-3&th=1
Edit: I forgot to mention that I am running Ubuntu 19.04.
jman
  • 185
I'd like to refer you to this answer : https://askubuntu.com/a/973582/307184
as anticipated, given the name "X" render, xrandr is incompatible with Wayland.
given Wayland is the default session on ubuntu 19.04 you cannot use xrandr (which is obsolete as 19.04 solves most to all display issues and comping with a more complete multi-monitor configurations menu built-in)
Basically your monitor is already at the correct resolution from a PC perspective and the only additional changes you can make must be found in the monitor setup itself (E.G. turn "overscan" off)
Fabby
  • 35,017
tatsu
  • 3,346
Use the auto adjust on your monitor by going to its menu and choosing: LCD Monitor TroubleshootingPicture or Text blurDisplay Position or Resolution not correctScreen color is abnormal or random jitter
  1. Automatic calibration (Auto Adjust): Press and hold the SPLENDID key for about 4 seconds for automatic correction.
    Note¹: Auto Adjust is valid only when the input is an analog signal (VGA).
    Note²: Not every model has an Auto Adjust hotkey.
  2. Please adjust the current resolution to the correct setting and refresh rate according to the different sizes in the below table:
    Ratio   Size    Resolution   Refresh Rate
    [4:3]      17"  1280x1024     60Hz
    [16:9]  23-46"  1920x1080     60Hz
               65"  1920x1080    120Hz
    [16:10]    20"  1680x1050     60Hz
               24": 1920x1200     60Hz
  3. Update the graphic card driver:
    My monitor cannot display proper resolution
  4. Monitor Reset: Back to the initial value of display: Hold down the MENU key and select MENUSystem SetupResetYes
  5. Check if the signal cable ( VGA / DVI / HDMI / DisplayPort / USB) is firmly seated and confirm the other end of the output cable has been firmly seated to the computer input port (graphics card). Unplug and plug 2-terminals again and make sure none of the pins are bent.
Source
Fabby
  • 35,017
