I have a Dell laptop with fingerprint reader built in. I just ran lsusb with the following result:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 138a:00a6 Validity Sensors, Inc.
Bus 001 Device 005: ID 0cf3:e009 Atheros Communications, Inc.
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 0bda:5689 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 04ca:00ac Lite-On Technology Corp.
Is it possible to use fingerprint scanning instead of traditional login with 18.04 and Unity ?
Yes, according to Ubuntu documentation.
Open the Activities overview and start typing Users.
Click on Users to open the panel.
Press on Disabled, next to Fingerprint Login to add a fingerprint for the selected account. If you are adding the fingerprint for a different user, you will first need to Unlock the panel.
Select the finger that you want to use for the fingerprint, then Next.
Follow the instructions in the dialog and swipe your finger at a moderate speed over your fingerprint reader. Once the computer has a good record of your fingerprint, you will see a Done! message.
Select Next. You will see a confirmation message that your fingerprint was saved successfully. Select Close to finish.
K7AAY
  • 17,705
