If you forgot to select some software at the "Software Selection" screen on a fresh install, what are the commands to install them after the fact. I know you can install them manually at anytime after everything is said and done, but what are the commands to install just as if you [*]starred them on that screen.
For instance:
sudo apt-get install lamp-server^
will install the LAMP Server. What are the commands for the DNS Server, Mail Server and Tomcat Java server?
Jorge Castro
  • 73,717
joe
  • 63
Even after the installer you can use tasksel to install tasks, it just needs installing:
sudo apt-get install tasksel
sudo tasksel
If you're just after a list of available tasks, tasksel is still the easiest way to achieve this. Install it and run tasksel --list-task and you get a nice list of the available tasks, their install status and a description.
And if you need a trimmed list, something like this should do:
tasksel --list-task | awk '{ print $2 }'
Oli
  • 299,380
