My machine has two network interfaces (wired and wireless). My problem is that I cannot use both my nic and my wireless nic at the same time. When my wireless nic is connected and then I connect my nic, my wireless nic gets disabled automatically once my nic becomes active. How do I disable this behavior?
I dug these critical messages from journalctl:
Jun 05 16:14:54 beast-att kernel: iwlwifi 0000:00:14.3: RF_KILL bit toggled to disable radio.
Jun 05 16:14:54 beast-att kernel: iwlwifi 0000:00:14.3: reporting RF_KILL (radio disabled)
Here is the output rfkill list:
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: dell-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
2: dell-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
3: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
iwlwifi has activated a hard block on phy0.
I have attempted to fix my issue with findings from this other question. I tried BIOS changes (turned off switching on my WLAN), playing with the wireless network toggle button, removing *wmi* modules, simply executing rfkill unblock all - nothing worked.
Here is my lsmod | grep wmi output:
$ lsmod | grep wmi
dell_wmi 16384 0
dell_smbios 24576 2 dell_wmi,dell_laptop
intel_wmi_thunderbolt 16384 0
mxm_wmi 16384 0
wmi_bmof 16384 0
dell_wmi_descriptor 16384 2 dell_wmi,dell_smbios
snd_rawmidi 32768 1 snd_seq_midi
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
snd 81920 17 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
wmi 24576 6 intel_wmi_thunderbolt,dell_wmi,wmi_bmof,dell_smbios,dell_wmi_descriptor,mxm_wmi
sparse_keymap 16384 2 intel_hid,dell_wmi
video 45056 3 dell_wmi,dell_laptop,i915
I tried removing dell_wmi, intel_wmi_thunderbolt, mxm_wmi using modprobe -r with no effect to my problem.
Here are details of my wireless nic using lspci -vk:
00:14.3 Network controller: Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10)
Subsystem: Intel Corporation Device 4030
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at ed43c000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] #00
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
I'm running ubuntu 18.04 on a Dell Precision 3530.
I've been looking for a solution to prevent the auto blocking but I'm also open to a solution that would allow me to manually unblock after the block has occurred.
Thank you in advance.
