A new Linux box was given to me with a Non-GUI version of Ubuntu 18.04.1 already installed, however, it seems to be stuck in a weird state that I've never encountered before...
I've tried compiling the quintessential Hello, World program using gcc with the following result:
#include <stdio.h>
int main() {
    printf("Hello, World!");
    return 0;
test.c:1:19: fatal error: stdio.h: No such file or directory
compilation terminated.
I've tried the suggestions posted in another question: C stdio.h no such file or directory but with no luck.
Reinstalling gcc-5, and running sudo apt-get update did not solve the issue. When trying to install build-essential I ran into a surprising amount of build dependencies that would not install.
ubuntu@ubuntu:~$ sudo apt install --reinstall build-essential
Reading package lists... Done
Building dependency tree
 build-essential : Depends: libc6-dev but it is not going to be installed or
                            libc-dev
                   Depends: g++ (>= 4:5.2) but it is not going to be installed
                   Depends: dpkg-dev (>= 1.17.11) but it is not going to be installed
ubuntu@ubuntu:~$ sudo apt install --reinstall build-essential libc6-dev g++ dpkg-dev
 dpkg-dev : Depends: libdpkg-perl (= 1.18.4ubuntu1.5) but it is not going to be installed
 libc6-dev : Depends: libc6 (= 2.23-0ubuntu11) but 2.27-3ubuntu1 is to be installed
             Depends: libc-dev-bin (= 2.23-0ubuntu11) but it is not going to be installed
ubuntu@ubuntu:~$ sudo apt install --reinstall build-essential libc6-dev g++ dpkg-dev libdpkg-perl libc-dev-bin
 bind9-host : Depends: libbind9-160 (= 1:9.11.3+dfsg-1ubuntu1.1) but it is not going to be installed
              Depends: libdns1100 (= 1:9.11.3+dfsg-1ubuntu1.1) but it is not going to be installed
              Depends: libisc169 (= 1:9.11.3+dfsg-1ubuntu1.1) but it is not going to be installed
              Depends: libisccfg160 (= 1:9.11.3+dfsg-1ubuntu1.1) but it is not going to be installed
 crda : Depends: libssl1.1 (>= 1.1.0) but it is not going to be installed
 cron : PreDepends: dpkg (>= 1.15.7.2) but it is not going to be installed
        Depends: libpam0g (>= 0.99.7.1) but it is not going to be installed
        Depends: adduser but it is not going to be installed
        Depends: libpam-runtime (>= 1.0.1-11) but it is not going to be installed
 init-system-helpers : Depends: perl-base (>= 5.20.1-3) but it is not going to be installed
 libc-dev-bin : Depends: libc6 (< 2.24) but 2.27-3ubuntu1 is to be installed
                Recommends: manpages-dev but it is not going to be installed
 libdpkg-perl : Depends: dpkg (>= 1.16.3) but it is not going to be installed
                Depends: perl but it is not going to be installed
                Recommends: libfile-fcntllock-perl but it is not going to be installed
 linux-headers-generic : Depends: linux-headers-4.15.0-29-generic but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
And so on... Running dpkg --get-selections | grep hold does not yeild any held packages. My GCC version: gcc (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.11) 5.4.0 20160609
Any help with this is greatly appreciated!
Tex4066
  • 121
