Software Updater has stopped giving me updates. No matter what I check from "Software Updater box, nothing changes.
It seems like there are not updates for my system anymore. However, this should not happen as I have version 16.04 LTS.
My system is a powerbook G4, I have lubuntu version 16.04 LTS installed. I am located in Greece.
I have read several solutions, nothing worked from me
  1. I deleted file sources.list (located in /etc/apt), and I let system recreate it. No result
  2. I used the repogen.simplylinux site to create a new content for my sources.list. No result
Output of sudo apt-get update:
Get:1 http://ports.ubuntu.com/ubuntu-ports xenial InRelease [247 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports xenial-security InRelease [109 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports xenial-updates InRelease [109 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports xenial/main powerpc Packages [1142 kB]
Ign:5 http://ports.ubuntu.com/ubuntu-ports xenial/main i386 Packages
Get:6 http://ports.ubuntu.com/ubuntu-ports xenial/main Translation-en [568 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports xenial/universe powerpc Packages [7297 kB]
Ign:8 http://ports.ubuntu.com/ubuntu-ports xenial/universe i386 Packages
Get:9 http://ports.ubuntu.com/ubuntu-ports xenial/universe Translation-en [4354 kB]
Ign:10 http://ports.ubuntu.com/ubuntu-ports xenial/restricted i386 Packages
Get:11 http://ports.ubuntu.com/ubuntu-ports xenial/restricted Translation-en [2908 B]
Get:12 http://ports.ubuntu.com/ubuntu-ports xenial/multiverse powerpc Packages [121 kB]
Ign:13 http://ports.ubuntu.com/ubuntu-ports xenial/multiverse i386 Packages
Get:14 http://ports.ubuntu.com/ubuntu-ports xenial/multiverse Translation-en [106 kB]
Ign:15 http://ports.ubuntu.com/ubuntu-ports xenial-security/restricted i386 Packages
Get:16 http://ports.ubuntu.com/ubuntu-ports xenial-security/restricted Translation-en [2152 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports xenial-security/main powerpc Packages [464 kB]
Ign:18 http://ports.ubuntu.com/ubuntu-ports xenial-security/main i386 Packages
Get:19 http://ports.ubuntu.com/ubuntu-ports xenial-security/main Translation-en [267 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports xenial-security/multiverse powerpc Packages [1716 B]
Ign:21 http://ports.ubuntu.com/ubuntu-ports xenial-security/multiverse i386 Packages
Get:22 http://ports.ubuntu.com/ubuntu-ports xenial-security/multiverse Translation-en [2676 B]
Get:23 http://ports.ubuntu.com/ubuntu-ports xenial-security/universe powerpc Packages [341 kB]
Ign:24 http://ports.ubuntu.com/ubuntu-ports xenial-security/universe i386 Packages
Get:25 http://ports.ubuntu.com/ubuntu-ports xenial-security/universe Translation-en [177 kB]
Ign:26 http://ports.ubuntu.com/ubuntu-ports xenial-updates/restricted i386 Packages
Get:27 http://ports.ubuntu.com/ubuntu-ports xenial-updates/restricted Translation-en [2272 B]
Get:28 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main powerpc Packages [724 kB]
Ign:29 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main i386 Packages
Get:30 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main Translation-en [381 kB]
Get:31 http://ports.ubuntu.com/ubuntu-ports xenial-updates/multiverse powerpc Packages [11,0 kB]
Ign:32 http://ports.ubuntu.com/ubuntu-ports xenial-updates/multiverse i386 Packages
Get:33 http://ports.ubuntu.com/ubuntu-ports xenial-updates/multiverse Translation-en [8440 B]
Get:34 http://ports.ubuntu.com/ubuntu-ports xenial-updates/universe powerpc Packages [623 kB]
Ign:35 http://ports.ubuntu.com/ubuntu-ports xenial-updates/universe i386 Packages
Get:36 http://ports.ubuntu.com/ubuntu-ports xenial-updates/universe Translation-en [312 kB]
Err:5 http://ports.ubuntu.com/ubuntu-ports xenial/main i386 Packages
  404  Not Found [IP: 2001:67c:1360:8001::22 80]
Err:15 http://ports.ubuntu.com/ubuntu-ports xenial-security/restricted i386 Packages
Err:26 http://ports.ubuntu.com/ubuntu-ports xenial-updates/restricted i386 Packages
Fetched 465 kB in 14s (32,1 kB/s)
Reading package lists... Done
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial/main/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001::22 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-security/restricted/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001::22 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-updates/restricted/binary-i386/Packages  404  Not Found [IP: 2001:67c:1360:8001::22 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Content of sources.list:
###### Ubuntu Main Repos
# deb http://us.archive.ubuntu.com/ubuntu/ xenial main
###### Ubuntu Update Repos
# deb http://us.archive.ubuntu.com/ubuntu/ xenial-security main
deb http://ports.ubuntu.com/ubuntu-ports/ xenial main universe restricted multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-security restricted main multiverse universe
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-updates restricted main multiverse universe
Update 2: Thank you for answer Oyamasiphula. This is the output (I think did not work)
Update 3: I ran "apt update". This is the output.
Update 4: At first I switched back my sources.list file. So now the content of my sources.list is this. Then sudo apt-update. The output was this
Then I ran: sudo dpkg --remove-architecture i386 and then sudo apt update The output was this. As suggested in the end, I executed apt list --upgradable. The output was this
And then I executed sudo apt upgrade and I got this
I terminated it, as I was not sure for what to do. Can you please explain what just happened here? Was my machine trying to get i386 packages? If yes, why? Also, should I proceed to update?
thank you a lot!!!!
Kulfy
  • 18,154
Since Lubuntu 16.04 went EOL in April 2019, all packages that were specific to Lubuntu will no longer receive updates. However, packages related to Ubuntu main will still receive updates. Considering this, the i386 packages are now removed from the repositories, thus resulting in the error.
Since you are running a PPC system, the i386 packages were never required. To remove them, run:
Now, you'll receive updates only for PPC packages in Ubuntu main. To upgrade those packages, run:
sudo apt update && sudo apt upgrade
xiota
  • 5,038
Kulfy
  • 18,154
