Problem: 5 minute delay on startup
Device: UP board (small x86 board), running 18.04, with a Panda PAU05 wireless USB adapter, connected via HDMI to a monitor
Network configuration: using netplan and systemd-networkd. NetworkManager is not installed.
When the Ethernet is connected, the device boots up quickly. I can unplug the Ethernet and rely on wifi. SSH works, etc.
When the Ethernet is not connected, there's a 5 minute delay. The console says A start job is running for Raise network interfaces (Xmin Ys / 5min 2s) and slowly counts up to 5min 2s. I can ping the device, but ssh is refused: ssh: connect to host rodeobot.local port 22: Connection refused. After 5 minutes the boot completes fine.
I tinkered with my netplan to make both ethernet and wifi interfaces optional, but this doesn't help. I also tried removing the ethernet interface, but that didn't help. Here's the /etc/netplan/config.yaml I'm running now:
network:
  version: 2
  renderer: networkd
  ethernets:
    enp1s0:
      optional: true  # Don't wait for Ethernet
      dhcp4: true
  wifis:
    wlx9cefd5fcb328:
      optional: true  # Don't wait for Wifi
      dhcp4: true
      access-points:
        "xxx":
          password: "yyy"
Edit: I see several similar questions, but I don't see an answer that uses netplan. Is this a bug / missing feature in netplan?
Edit: fixed indentation and commenting in config.yaml. (I copied and pasted, then edited the ssid and pw.)
Edit: here's the result of sudo netplan --debug generate:
** (generate:965): DEBUG: 18:35:38.361: Processing input file /etc/netplan/config.yaml..
** (generate:965): DEBUG: 18:35:38.362: starting new processing pass
** (generate:965): DEBUG: 18:35:38.362: wlx9cefd5fcb328: adding wifi AP 'Beckett'
** (generate:965): DEBUG: 18:35:38.362: wlx9cefd5fcb328: setting default backend to 1
** (generate:965): DEBUG: 18:35:38.362: Configuration is valid
** (generate:965): DEBUG: 18:35:38.362: enp1s0: setting default backend to 1
** (generate:965): DEBUG: 18:35:38.363: Generating output files..
** (generate:965): DEBUG: 18:35:38.363: NetworkManager: definition enp1s0 is not for us (backend 1)
** (generate:965): DEBUG: 18:35:38.363: wlx9cefd5fcb328: Creating wpa_supplicant configuration file run/netplan/wpa-wlx9cefd5fcb328.conf
** (generate:965): DEBUG: 18:35:38.363: Creating wpa_supplicant service enablement link /run/systemd/system/systemd-networkd.service.wants/netplan-wpa@wlx9cefd5fcb328.service
** (generate:965): DEBUG: 18:35:38.364: NetworkManager: definition wlx9cefd5fcb328 is not for us (backend 1)
Thanks.
network:
  version: 2
  renderer: networkd
  ethernets:
    enp1s0:
      optional: true
      dhcp4: true
  wifis:
    wlx9cefd5fcb328:
      optional: true
      dhcp4: true
      access-points:
        "xxx":
          password: "yyy"
sudo netplan generate # generate config files
sudo netplan apply # apply new configuration
reboot # verify proper operation
heynnema
  • 73,649
It turns out that enp1s0 wasn't managed by systemd-networkd, and therefore netplan had no effect. I discovered this by looking at the logs:
journalctl | grep enp1s0 | grep "managed by us"
I found a number of entries that looked like this:
systemd-networkd: enp1s0: Link is not managed by us
The fix was to remove the ifupdown package. For good measure (and to make sure I didn't forget!) I moved the /etc/network directory:
sudo apt remove ifupdown
sudo mv /etc/network /etc/network_old_ifupdown
sudo reboot now
While looking at the logs I also fixed a problem with resolv.conf -- I had a bad symlink. There's a good explanation here: New alert keeps showing up: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001
Thanks to folks that helped!
Setting sudo nano /etc/network/interfaces
#from
auto lo br0
iface lo inet loopback
# to
auto lo
allow-hotplug br0
helped. The slow startup occurred under Ubuntu 18.04 after following this tutorial to install KVM.
hb0
  • 251
