I installed the tree command today on Ubuntu 18.04 using:
$ sudo apt update
$ sudo apt install tree
The version that was installed is:
$ tree --version
tree v1.7.0 (c) 1996 - 2014
But I see from here the latest version is 1.8.0
How can I install the latest version of tree? More generally, how can I ensure the latest versions of programs get installed?
Kulfy
  • 18,154
cjt
  • 163
You can use either of the two methods to install tree 1.8.0:
  1. Using Snap:
    Tree is available as a snap package too. You can install it using
    snap install tree
    Verify version:
    tree --version
  2. Installing deb package:
    Tree 1.8.0 is packed in Ubuntu 19.04 (Disco Dingo). Tree 1.8.0 depends on lib6 (>=2.17). In 18.04 lib6 v2.27 is available. You can download the deb package from Ubuntu pool and install that using dpkg.
    • Download deb package:
      wget https://mirrors.edge.kernel.org/ubuntu/pool/universe/t/tree/tree_1.8.0-1_amd64.deb
    • Install using dpkg:
      sudo dpkg -i tree_1.8.0-1_amd64.deb
    • Install any left dependency:
      sudo apt install -f
    • Verify version:
      tree --version
      You must get an output like:
      tree v1.8.0 (c) 1996 - 2018 by Steve Baker, Thomas Moore, Francesc Rocher, Florian Sesser, Kyosuke Tokoro
Further Reading:
Kulfy
  • 18,154
Download the source package.
decompress the source package. Change directory into the tree-1.8.0 directory open a terminal, and type make
from the INSTALL File in tree-1.8.0 source:
Installation instructions:
  1. Edit the Makefile for your OS. Comment out the Linux options and un-comment the options for your OS.
  2. Type: make
  3. Type: make install
  4. Enjoy colorful directory trees.
you may find it necessary to run sudo make install if you see "permission denied", do that. I also looked at the MakeFile, you shouldnt have to change anything, just go to step 2, and give the make command. if you get errors, update your post.
j0h
  • 15,365
