I have 3 NICs. NIC1 and NIC2 are used for internet connections an LAN is used for intranet connection.
I want to balance the load to ISPs using ip tables. As I am a noob, my crude attempt is given in the following code, obviously without success. This code was assembled by looking at many websites on the topic.
we would like to optimally use the incoming internet in LAN using Round-Robin method
or
Is it possible to split the two isps, i.e, for systems 1 to 5 (ISP1) and 5 to 10 (ISP2) using routing tables?
Hope someone out there will help me, which is very much appreciated.
set -x
IPT="/sbin/iptables"
NIC1="enp4s5f0"
NIC2="enp4s5f1"
LAN="ens2"
ISP1="192.168.9.33"
ISP2="192.168.10.33"
# reset iptables
#_______________
## reset the default policies in the filter table.
$IPT -P INPUT ACCEPT
$IPT -P FORWARD ACCEPT
$IPT -P OUTPUT ACCEPT
## reset the default policies in the nat table.
$IPT -t nat -P PREROUTING ACCEPT
$IPT -t nat -P POSTROUTING ACCEPT
$IPT -t nat -P OUTPUT ACCEPT
## reset the default policies in the mangle table.
$IPT -t mangle -P PREROUTING ACCEPT
$IPT -t mangle -P OUTPUT ACCEPT
## flush all the rules in the filter and nat tables.
$IPT -F
$IPT -t nat -F
$IPT -t mangle -F
## erase all chains that's not default in filter and nat table.
$IPT -X
$IPT -t nat -X
$IPT -t mangle -X
# enable IP forwarding
#_____________________
echo 1 > /proc/sys/net/ipv4/ip_forward
# rules
#________________
$IPT -A INPUT -m state --state INVALID -j DROP
$IPT -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
$IPT -A INPUT -p icmp -j ACCEPT
$IPT -A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
$IPT -A INPUT -p tcp -m tcp --dport 80 -j ACCEPT
$IPT -A FORWARD -m state --state INVALID -j DROP
$IPT -A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
$IPT -A FORWARD -p icmp -j ACCEPT
$IPT -t nat -A PREROUTING -i NIC1 -p tcp --dport 80\
-m state --state NEW -m statistic --mode\
random --probability .33 -j DNAT --to-destination 10.1.1.1:1
$IPT -t nat -A PREROUTING -i NIC2 -p tcp --dport 80\
random --probability .33 -j DNAT --to-destination 10.1.1.1:2
$IPT -A FORWARD -i $NIC1 -o $LAN -j ACCEPT
$IPT -A FORWARD -i $NIC2 -o $LAN -j ACCEPT
# ifconfig -a
# allow certain hosts full access
#________________________________
allowHost() {
$IPT -A FORWARD -i $LAN -s $1 -j ACCEPT
allowHost 192.168.2.10
allowHost 192.168.2.11
allowHost 192.168.2.12
allowHost 192.168.2.13
allowHost 192.168.2.14
allowHost 192.168.2.15
####Extra
$IPT -A FORWARD -d 8.8.8.8 -p tcp -m multiport --dports 53 -j ACCEPT
# block anything else
$IPT -A FORWARD -j LOG -m limit --limit 10/minute --limit-burst 1 --log-prefix "Blocked:"
$IPT -A FORWARD -j DROP
/sbin/modprobe ip_tables
/sbin/modprobe ip_conntrack
/sbin/modprobe ip_conntrack_ftp
/sbin/modprobe ip_nat_ftp
/sbin/modprobe iptable_nat
