I have downloaded an SD image loader from nxp website.
The name of the downloaded item is O8.1.0_1.4.0_ANDROID_TOOL_7ULP_GA (This is not an Android question btw).
The image loaded on my SD is inside the zipped file under the name of
recovery-imx7ulp.img
I would like to modify this image before I load SD with this file. What software should I use to open this image? I cannot identify the filesystem.
This .img file could be a raw image. But, still I have no idea how to mount it.
Here are my tries.
mount
sudo mount -t auto recovery-imx7ulp.img ./img -o loop
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
dmesg | tail
[ 124.816635] IPv6: ADDRCONF(NETDEV_UP): ens33: link is not ready
[ 124.828615] IPv6: ADDRCONF(NETDEV_UP): ens33: link is not ready
[ 124.829592] e1000: ens33 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
[ 124.831624] IPv6: ADDRCONF(NETDEV_CHANGE): ens33: link becomes ready
[ 141.529441] NET: Registered protocol family 40
fdisk
fdisk -lu recovery-imx7ulp.img
Disk recovery-imx7ulp.img: 32 MiB, 33554432 bytes, 65536 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
file
file recovery-imx7ulp.img
Android bootimg,
kernel (0x62808000),
ramdisk (0x63800000),
second stage (0x63700000),
page size: 2048,
cmdline (console=ttyLP0,115200 init=/init androidboot.console=ttyLP0 con)
parted
sudo parted recovery-imx7ulp.img
GNU Parted 3.2
Using /home/ar/tmp/recovery-imx7ulp.img
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) u
Unit? [compact]? B
(parted) print
Error: /home/ar/tmp/recovery-imx7ulp.img: unrecognised disk label
Model: (file)
Disk /home/ar/tmp/recovery-imx7ulp.img: 33554432B
Sector size (logical/physical): 512B/512B
Partition Table: unknown
Disk Flags:
(parted) ^C
losetup
losetup -P recovery-imx7ulp.img
losetup: recovery-imx7ulp.img: failed to use device: Success
sudo losetup --offset 115200 /dev/loop2 recovery-imx7ulp.img
sudo fsck -fv /dev/loop2
fsck from util-linux 2.27.1
e2fsck 1.42.13 (17-May-2015)
ext2fs_open2: Bad magic number in super-block
fsck.ext2: Superblock invalid, trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/loop2
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
sudo losetup -d /dev/loop2
blkid
blkid -o value -s TYPE recovery-imx7ulp.img
(empty output)
disktype
sudo disktype recovery-imx7ulp.img
--- recovery-imx7ulp.img
Regular file, size 32 MiB (33554432 bytes)
Head of the file in hex
hexdump -C recovery-imx7ulp.img | head -40
00000000 41 4e 44 52 4f 49 44 21 08 f1 8e 00 00 80 80 62 |ANDROID!.......b|
00000010 00 17 55 00 00 00 80 63 b4 54 00 00 00 00 70 63 |..U....c.T....pc|
00000020 00 01 80 62 00 08 00 00 00 00 00 00 00 00 00 00 |...b............|
00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000040 63 6f 6e 73 6f 6c 65 3d 74 74 79 4c 50 30 2c 31 |console=ttyLP0,1|
00000050 31 35 32 30 30 20 69 6e 69 74 3d 2f 69 6e 69 74 |15200 init=/init|
00000060 20 61 6e 64 72 6f 69 64 62 6f 6f 74 2e 63 6f 6e | androidboot.con|
00000070 73 6f 6c 65 3d 74 74 79 4c 50 30 20 63 6f 6e 73 |sole=ttyLP0 cons|
00000080 6f 6c 65 62 6c 61 6e 6b 3d 30 20 61 6e 64 72 6f |oleblank=0 andro|
00000090 69 64 62 6f 6f 74 2e 68 61 72 64 77 61 72 65 3d |idboot.hardware=|
000000a0 66 72 65 65 73 63 61 6c 65 20 76 6d 61 6c 6c 6f |freescale vmallo|
000000b0 63 3d 31 32 38 4d 20 63 6d 61 3d 34 34 38 4d 20 |c=128M cma=448M |
000000c0 62 75 69 6c 64 76 61 72 69 61 6e 74 3d 75 73 65 |buildvariant=use|
000000d0 72 64 65 62 75 67 00 00 00 00 00 00 00 00 00 00 |rdebug..........|
000000e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000240 c4 ab 31 08 3f 94 04 fb 09 88 86 e6 d6 c2 af 99 |..1.?...........|
00000250 d4 5e ac b7 00 00 00 00 00 00 00 00 00 00 00 00 |.^..............|
00000260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000800 00 00 a0 e1 00 00 a0 e1 00 00 a0 e1 00 00 a0 e1 |................|
00000820 03 00 00 ea 18 28 6f 01 00 00 00 00 08 f1 8e 00 |.....(o.........|
00000830 01 02 03 04 00 90 0f e1 20 05 00 eb 01 70 a0 e1 |........ ....p..|
00000840 02 80 a0 e1 00 20 0f e1 03 00 12 e3 01 00 00 1a |..... ..........|
00000850 17 00 a0 e3 56 34 12 ef 00 00 0f e1 1a 00 20 e2 |....V4........ .|
00000860 1f 00 10 e3 1f 00 c0 e3 d3 00 80 e3 04 00 00 1a |................|
00000870 01 0c 80 e3 0c e0 8f e2 00 f0 6f e1 0e f3 2e e1 |..........o.....|
00000880 6e 00 60 e1 00 f0 21 e1 09 f0 6f e1 00 00 00 00 |n.`...!...o.....|
00000890 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000008a0 0f 40 a0 e1 3e 43 04 e2 02 49 84 e2 0f 00 a0 e1 |.@..>C...I......|
000008b0 04 00 50 e1 ac 01 9f 35 0f 00 80 30 00 00 54 31 |..P....5...0..T1|
000008c0 01 40 84 33 6d 00 00 2b 5e 0f 8f e2 4e 1c 90 e8 |.@.3m..+^...N...|
000008d0 1c d0 90 e5 01 00 40 e0 00 60 86 e0 00 a0 8a e0 |......@..`......|
000008e0 00 90 da e5 01 e0 da e5 0e 94 89 e1 02 e0 da e5 |................|
000008f0 03 a0 da e5 0e 98 89 e1 0a 9c 89 e1 00 d0 8d e0 |................|
00000900 01 a8 8d e2 00 50 a0 e3 01 a9 8a e2 0a 00 54 e1 |.....P........T.|
00000910 1e 00 00 2a 09 a0 84 e0 70 90 8f e2 09 00 5a e1 |...*....p.....Z.|
00000920 1a 00 00 9a 09 ac 8a e2 ff a0 ca e3 6c 50 4f e2 |............lPO.|
00000930 1f 50 c5 e3 00 00 4f e1 1f 00 00 e2 1a 00 50 e3 |.P....O.......P.|
Also no luck with
sudo kpartx -av recovery-imx7ulp.img
gnome-disk-image-mounter recovery-imx7ulp.img
gparted
sudo gparted imx7ulp_m4_demo.img
libparted : 3.2
/home/tmp/recovery-imx7ulp.img: unrecognised disk label
simg2img
simg2img imx7ulp_m4_demo.img out.img
Invalid sparse file format at header magi
Failed to read sparse file
