I recently upgraded from Ubuntu 18.04 to Ubuntu 18.10 using the command line command sudo do-release-upgrade and after that, whenever I run sudo apt upgrade, all I see is the following: -
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  bind9-host dnsutils evolution-data-server fwupdate libbind9-160 libebackend-1.2-10 libebook-1.2-19 libebook-contacts-1.2-2 libecal-1.2-19
  libedata-book-1.2-25 libedataserver-1.2-23 libedataserverui-1.2-2 libfwup1 libirs160 libisc169 libisccc160 libisccfg160 liblwres160
0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
How can I fix this? I want to upgrade to Ubuntu 19.04 and this is getting in my way. Also, on running sudo apt update I see this warning: -
W: Target Sources (restricted/source/Sources) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list:7
EDIT: -
I got rid of the duplicates, now when I do sudo apt update it says: -
18 packages can be upgraded. Run 'apt list --upgradable' to see them.
but on doing sudo apt upgrade, it's still the same.
EDIT 2: -
I found the solution, apparently, sudo apt full-upgrade did the trick. Thank you everyone for helping me out!
TheDrone7
  • 23
You have duplicate entries in your sources.list
You should check them in that file (/etc/apt/sources.list)
Another way is:
going to
System settings >> Software and Updates >> Other Software and removing each duplicate entry.
