For the past day I have trying to get the Nvidia drivers to work on my 10 year old PC running Lubuntu 16.04.6 LTS as recommended here. The automatically installed drivers did not work, so I typed glxinfo and all I got was
Xlib: extension "GLX" missing on display ":0.0".
Error: couldn't find RGB GLX visual or fbconfig
I have trawled the internet, following guides such as this one and many more very similar ones, mostly advising me to install nvidia-304 as opposed to nvidia-304-updates, the only two differences I can see between the two is that the nvidia-304-updates package runs at 800x600 resolution whereas the nvidia-304 package runs at (I think) 1280x800. My monitor's resolution is 1280x1024. More importantly, when running the last command in that sequence sudo nvidia-xconfig I get left with this:
Using X configuration file: "/etc/X11/xorg.conf".
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
But that's besides the point. why are the graphics drivers not installing correctly, and how do I install them correctly?
FYI here are my system specs copy-pasted off my linked question, ignore OS, Kernel etc:
System information report, generated by Sysinfo: 27/05/2019 17:18:20
http://sourceforge.net/projects/gsysinfo
SYSTEM INFORMATION
Running LinuxMint Linux, the LinuxMint 19.1 (tessa) release.
GNOME: 3.28.2 (Ubuntu)
Kernel version: 4.15.0-20-generic (#21-Ubuntu SMP Tue Apr 24 06:16:15 UTC 2018)
GCC: 7 (x86_64-linux-gnu)
Xorg: 1.19.6 (25 October 2018 04:11:27PM) (25 October 2018 04:11:27PM)
Hostname: jeremy-ixtreme-M3720
Uptime: 0 days 0 h 49 min
CPU INFORMATION
GenuineIntel, Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Number of CPUs: 4
CPU clock currently at 2000.092 MHz with 2048 KB cache
Numbering: family(6) model(23) stepping(10)
Bogomips: 4999.94
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl cpuid aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 xsave lahf_lm pti tpr_shadow vnmi flexpriority dtherm
MEMORY INFORMATION
Total memory: 7724 MB
Total swap: 2047 MB
STORAGE INFORMATION
SCSI device - scsi3
Vendor: ATAPI
Model: DVD A DH16AASH
SCSI device - scsi4
Vendor: ATA
Model: ADATA SU650
SCSI device - scsi6
Vendor: Generic
Model: USB SD Reader
SCSI device - scsi6
Vendor: Generic
Model: USB CF Reader
HARDWARE INFORMATION
MOTHERBOARD
Host bridge
NVIDIA Corporation MCP73 Host Bridge (rev a2)
Subsystem: Acer Incorporated [ALI] MCP73 Host Bridge
PCI bridge(s)
NVIDIA Corporation MCP73 PCI Express bridge (rev a1) (prog-if 01 [Subtractive decode])
NVIDIA Corporation MCP73 PCI Express bridge (rev a1) (prog-if 00 [Normal decode])
ISA bridge
NVIDIA Corporation MCP73 LPC Bridge (rev a2)
Subsystem: Acer Incorporated [ALI] MCP73 LPC Bridge
IDE interface
NVIDIA Corporation MCP73 IDE Controller (rev a1) (prog-if 8a [Master SecP PriP])
Subsystem: Acer Incorporated [ALI] MCP73 IDE Controller
GRAPHIC CARD
VGA controller
NVIDIA Corporation C73 [GeForce 7100 / nForce 630i] (rev a2) (prog-if 00 [VGA controller])
Subsystem: Acer Incorporated [ALI] C73 [GeForce 7100 / nForce 630i]
SOUND CARD
Multimedia controller
NVIDIA Corporation MCP73 High Definition Audio (rev a1)
Subsystem: Acer Incorporated [ALI] MCP73 High Definition Audio
NETWORK
Ethernet controller
Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 01)
Subsystem: Acer Incorporated [ALI] RTL810xE PCI Express Fast Ethernet controller
EDIT 1: The graphical installer comes up with the same errors.
Output of lsb_release -a:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
