why is sensors-detect giving only coretemp as an output without the motherboard information, trying to control cpu gpu fans Ubuntu 14.04
output of sensors detect:
sensors-detect revision 6170 (2013-05-20 21:25:22 +0200)
System: Micro-Star International Co., Ltd. GS63VR 6RF [REV:1.0] (laptop)
Board: Micro-Star International Co., Ltd. MS-16K2
This program will help you determine which kernel modules you need to load to use lm_sensors most effectively. It is generally safe and recommended to accept the default answers to all questions, unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors. Do you want to scan for them? This is totally safe. (YES/no): y Module cpuid loaded successfully. Silicon Integrated Systems SIS5595... No VIA VT82C686 Integrated Sensors... No VIA VT8231 Integrated Sensors... No AMD K8 thermal sensors... No AMD Family 10h thermal sensors... No AMD Family 11h thermal sensors... No AMD Family 12h and 14h thermal sensors... No AMD Family 15h thermal sensors... No AMD Family 15h power sensors... No AMD Family 16h power sensors... No Intel digital thermal sensor... Success! (driver `coretemp') Intel AMB FB-DIMM thermal sensor... No VIA C7 thermal sensor... No VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to standard I/O ports to probe them. This is usually safe. Do you want to scan for Super I/O sensors? (YES/no): y Probing for Super-I/O at 0x2e/0x2f Trying family National Semiconductor/ITE'... No Trying familySMSC'... No Trying family VIA/Winbond/Nuvoton/Fintek'... No Trying familyITE'... No Probing for Super-I/O at 0x4e/0x4f Trying family National Semiconductor/ITE'... No Trying familySMSC'... No Trying family VIA/Winbond/Nuvoton/Fintek'... No Trying familyITE'... No
Some hardware monitoring chips are accessible through the ISA I/O ports. We have to write to arbitrary I/O ports to probe them. This is usually safe though. Yes, you do have ISA I/O ports even if you do not have any ISA slots! Do you want to scan the ISA I/O ports? (YES/no): y Probing for National Semiconductor LM78' at 0x290... No Probing forNational Semiconductor LM79' at 0x290... No Probing for Winbond W83781D' at 0x290... No Probing forWinbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware monitoring devices. This is the most risky part, and while it works reasonably well on most systems, it has been reported to cause trouble on some systems. Do you want to probe the I2C/SMBus adapters now? (YES/no): y Found unknown SMBus adapter 8086:a123 at 0000:00:1f.4. Sorry, no supported PCI bus adapters found.
Next adapter: i915 gmbus dpc (i2c-0) Do you want to scan it? (yes/NO/selectively): y
Next adapter: i915 gmbus dpb (i2c-1) Do you want to scan it? (yes/NO/selectively): y
Next adapter: i915 gmbus dpd (i2c-2) Do you want to scan it? (yes/NO/selectively): y Client found at address 0x19 Probing for Analog Devices ADM1021'... No Probing forAnalog Devices ADM1021A/ADM1023'... No Probing for Maxim MAX1617'... No Probing forMaxim MAX1617A'... No Probing for Maxim MAX1668'... No Probing forMaxim MAX1805'... No Probing for Maxim MAX1989'... No Probing forMaxim MAX6655/MAX6656'... No Probing for TI THMC10'... No Probing forNational Semiconductor LM84'... No Probing for Genesys Logic GL523SM'... No Probing forOnsemi MC1066'... No Probing for Maxim MAX1618'... No Probing forMaxim MAX1619'... No Probing for National Semiconductor LM82/LM83'... No Probing forMaxim MAX6654'... No Probing for Maxim MAX6690'... No Probing forMaxim MAX6680/MAX6681'... No Probing for Maxim MAX6695/MAX6696'... No Probing forTexas Instruments AMC6821'... No Probing for National Semiconductor LM95231'... No Probing forNational Semiconductor LM95241'... No Probing for National Semiconductor LM95245'... No Probing forST STTS424'... No Probing for ST STTS424E'... No Probing forST STTS2002'... No Probing for ST STTS3000'... No Probing forNXP SE97/SE97B'... No Probing for NXP SE98'... No Probing forAnalog Devices ADT7408'... No Probing for IDT TS3000/TSE2002'... No Probing forMaxim MAX6604'... No Probing for Microchip MCP9804'... No Probing forMicrochip MCP98242'... No Probing for Microchip MCP98243'... No Probing forMicrochip MCP98244'... No Probing for Microchip MCP9843'... No Probing forON CAT6095/CAT34TS02'... No Probing for Atmel AT30TS00'... No Client found at address 0x1c Probing forTexas Instruments TMP421'... No Probing for SMSC EMC1072'... No Probing forSMSC EMC1073'... No Probing for SMSC EMC1074'... No Probing forST STTS424'... No Probing for ST STTS424E'... No Probing forST STTS2002'... No Probing for ST STTS3000'... No Probing forNXP SE97/SE97B'... No Probing for NXP SE98'... No Probing forAnalog Devices ADT7408'... No Probing for IDT TS3000/TSE2002'... No Probing forMaxim MAX6604'... No Probing for Microchip MCP9804'... No Probing forMicrochip MCP98242'... No Probing for Microchip MCP98243'... No Probing forMicrochip MCP98244'... No Probing for Microchip MCP9843'... No Probing forON CAT6095/CAT34TS02'... No Probing for Atmel AT30TS00'... No Client found at address 0x1f Probing forTexas Instruments TMP421'... No Probing for ST STTS424'... No Probing forST STTS424E'... No Probing for ST STTS2002'... No Probing forST STTS3000'... No Probing for NXP SE97/SE97B'... No Probing forNXP SE98'... No Probing for Analog Devices ADT7408'... No Probing forIDT TS3000/TSE2002'... No Probing for Maxim MAX6604'... No Probing forMicrochip MCP9804'... No Probing for Microchip MCP98242'... No Probing forMicrochip MCP98243'... No Probing for Microchip MCP98244'... No Probing forMicrochip MCP9843'... No Probing for ON CAT6095/CAT34TS02'... No Probing forAtmel AT30TS00'... No Client found at address 0x29 Probing for National Semiconductor LM78'... No Probing forNational Semiconductor LM79'... No Probing for National Semiconductor LM80'... No Probing forNational Semiconductor LM96080'... No Probing for Winbond W83781D'... No Probing forWinbond W83782D'... No Probing for Winbond W83627HF'... No Probing forWinbond W83627EHF'... No Probing for Winbond W83627DHG/W83667HG/W83677HG'... No Probing forAsus AS99127F (rev.1)'... No Probing for Asus AS99127F (rev.2)'... No Probing forAsus ASB100 Bach'... No Probing for Analog Devices ADM1021'... No Probing forAnalog Devices ADM1021A/ADM1023'... No Probing for Maxim MAX1617'... No Probing forMaxim MAX1617A'... No Probing for Maxim MAX1668'... No Probing forMaxim MAX1805'... No Probing for Maxim MAX1989'... No Probing forMaxim MAX6655/MAX6656'... No Probing for TI THMC10'... No Probing forNational Semiconductor LM84'... No Probing for Genesys Logic GL523SM'... No Probing forOnsemi MC1066'... No Probing for Maxim MAX1618'... No Probing forMaxim MAX1619'... No Probing for National Semiconductor LM82/LM83'... No Probing forMaxim MAX6654'... No Probing for Maxim MAX6690'... No Probing forMaxim MAX6680/MAX6681'... No Probing for Maxim MAX6695/MAX6696'... No Probing forNational Semiconductor LM95245'... No Probing for Analog Devices ADM1029'... No Probing forITE IT8712F'... No Probing for SMSC EMC1402'... No Probing forSMSC EMC1403'... No Probing for SMSC EMC1404'... No Client found at address 0x2b Probing forNational Semiconductor LM78'... No Probing for National Semiconductor LM79'... No Probing forNational Semiconductor LM80'... No Probing for National Semiconductor LM96080'... No Probing forWinbond W83781D'... No Probing for Winbond W83782D'... No Probing forWinbond W83627HF'... No Probing for Winbond W83627EHF'... No Probing forWinbond W83627DHG/W83667HG/W83677HG'... No Probing for Asus AS99127F (rev.1)'... No Probing forAsus AS99127F (rev.2)'... No Probing for Asus ASB100 Bach'... No Probing forAnalog Devices ADM1021'... No Probing for Analog Devices ADM1021A/ADM1023'... No Probing forMaxim MAX1617'... No Probing for Maxim MAX1617A'... No Probing forMaxim MAX1668'... No Probing for Maxim MAX1805'... No Probing forMaxim MAX1989'... No Probing for Maxim MAX6655/MAX6656'... No Probing forTI THMC10'... No Probing for National Semiconductor LM84'... No Probing forGenesys Logic GL523SM'... No Probing for Onsemi MC1066'... No Probing forMaxim MAX1618'... No Probing for Maxim MAX1619'... No Probing forNational Semiconductor LM82/LM83'... No Probing for Maxim MAX6654'... No Probing forMaxim MAX6690'... No Probing for Maxim MAX6680/MAX6681'... No Probing forMaxim MAX6695/MAX6696'... No Probing for National Semiconductor LM95231'... No Probing forNational Semiconductor LM95241'... No Probing for Analog Devices ADM1029'... No Probing forITE IT8712F'... No Client found at address 0x49 Probing for National Semiconductor LM75'... No Probing forNational Semiconductor LM75A'... No Probing for Dallas Semiconductor DS75'... No Probing forNational Semiconductor LM77'... No Probing for Analog Devices ADT7410/ADT7420'... No Probing forMaxim MAX6642'... No Probing for National Semiconductor LM73'... No Probing forNational Semiconductor LM92'... No Probing for National Semiconductor LM76'... No Probing forMaxim MAX6633/MAX6634/MAX6635'... No Probing for NXP/Philips SA56004'... No Probing forSMSC EMC1023'... No Probing for SMSC EMC1043'... No Probing forSMSC EMC1053'... No Probing for SMSC EMC1063'... No Client found at address 0x4d Probing forNational Semiconductor LM75'... No Probing for National Semiconductor LM75A'... No Probing forDallas Semiconductor DS75'... No Probing for Analog Devices ADM1021'... No Probing forAnalog Devices ADM1021A/ADM1023'... No Probing for Global Mixed-mode Technology G781'... No Probing forMaxim MAX1617'... No Probing for Maxim MAX1617A'... No Probing forMaxim MAX1668'... No Probing for Maxim MAX1805'... No Probing forMaxim MAX1989'... No Probing for Maxim MAX6642'... No Probing forMaxim MAX6655/MAX6656'... No Probing for TI THMC10'... No Probing forNational Semiconductor LM84'... No Probing for Genesys Logic GL523SM'... No Probing forOnsemi MC1066'... No Probing for Maxim MAX1618'... No Probing forMaxim MAX1619'... No Probing for National Semiconductor LM82/LM83'... No Probing forNational Semiconductor LM89/LM99'... No Probing for Analog Devices ADM1032'... No Probing forMaxim MAX6654'... No Probing for Maxim MAX6690'... No Probing forMaxim MAX6659'... No Probing for Maxim MAX6646'... No Probing forMaxim MAX6680/MAX6681'... No Probing for Maxim MAX6695/MAX6696'... No Probing forTexas Instruments TMP411'... No Probing for Texas Instruments TMP421'... No Probing forTexas Instruments TMP422'... No Probing for Texas Instruments TMP423'... No Probing forTexas Instruments TMP431'... No Probing for Texas Instruments TMP432'... No Probing forTexas Instruments AMC6821'... No Probing for National Semiconductor LM95234'... No Probing forNational Semiconductor LM95245'... No Probing for National Semiconductor LM73'... No Probing forMaxim MAX6633/MAX6634/MAX6635'... No Probing for Analog Devices ADT7461'... No Probing forAnalog Devices ADT7461A, ON Semiconductor NCT1008'... No Probing for NXP/Philips SA56004'... No Probing forFintek F75384S/M'... No Probing for SMSC EMC1002'... No Probing forSMSC EMC1023'... No Probing for SMSC EMC1033'... No Probing forSMSC EMC1043'... No Probing for SMSC EMC1046'... No Probing forSMSC EMC1053'... No Probing for SMSC EMC1063'... No Probing forSMSC EMC1402'... No Probing for SMSC EMC1403'... No Probing forSMSC EMC1404'... No Client found at address 0x77 Probing for `Asus Mozart-2'... No
Next adapter: DPDDC-A (i2c-3) Do you want to scan it? (YES/no/selectively): y Client found at address 0x50 Probing for Analog Devices ADM1033'... No Probing forAnalog Devices ADM1034'... No Probing for SPD EEPROM'... No Probing forEDID EEPROM'... Yes (confidence 8, not a hardware monitoring chip)
Next adapter: DPDDC-C (i2c-4) Do you want to scan it? (YES/no/selectively): y
Now follows a summary of the probes I have just done. Just press ENTER to continue:
Driver coretemp': * ChipIntel digital thermal sensor' (confidence: 9)
To load everything that is needed, add this to /etc/modules:
----cut here----
Chip drivers
coretemp
----cut here----
If you have some drivers built into your kernel, the list above will contain too many modules. Skip the appropriate ones!
My output at the bottom:
https://i.sstatic.net/HYUwg.png
Tutorial output: http://imgur.com/gallery/LJcBrUb
The line of w83627ehf is missing from the output of sensors-detect on my PC
Tab_ninja
