Recently I bought a Nvidia GTX 1660 graphics card, and I already have windows 10 and I installed Ubuntu 19.04 alongside windows 10.
I added the graphics driver PPA and installed Nvidia drivers using the command
sudo apt-get install nvidia-driver-430
everything worked fine until I reboot and it is stuck at the boot screen as below:
Boot screen
I did everything I could. I am sharing all of them
Try 1: I booted in recovery mode and selected the following option
dpkg             Repair broken packages
Previously a few times this solved my problem and computer booted successfully with nvidia drivers but nowdays it does not solve my problem.
Try 2: I booted in recovery mode and I opened root terminal from there and uninstalled nvidia driver using
sudo apt-get purge nvidia*
Then everything went fine and I successfully booted without nvidia driver and now my screen resolution reduced to 1024x768
PLEASE HELP ME TO INSTALL NVIDIA DRIVER PROPERLY. I'D BE GRATEFUL.
Mark97
To begin with: First, enable your secure boot feature in the BIOS.
Second remove and purge all your nvidia packages using:
then to remove other dependencies of the NVIDIA driver:
apt-get autoremove
Then, reboot and
apt-get install nvidia-driver-4xx
where xx is the version number.
At the end of installation process it will ask you to set a secure boot password, set it to something (but remember it and write it down).
Then proceed to reboot, which then you will be asked to enroll the key
  • choose it then enter your password
  • exit it and proceed to boot.
  • Done
zx485
  • 2,865
There is a lot of solutions of this problem. But I found the simplest solution, which is to disable secure boot. So, if anyone having the same problem, they should disable secure boot first and check.
Mark97
