So I want to play Pubg lite, is there anyway to play it using ubuntu? And if I installed windows 10 in virtual box is it possible to play it smoothly?
Ubuntu version is 19.04
Natively: No. It requires dotnet as we do not have that. The best next alternative is virtualization. If you have a Windows license you can also dual boot.
Yes, Windows virtualised is almost the same as a normal Windows. The only thing you miss is a bit of power: you run an OS inside an OS. A nice amount of RAM is advisable. Mind though that in theory you could set the amount of RAM used by Windows pretty high if you do not use Ubuntu at the same time.
Rinzwind
  • 309,379
