I have Ubuntu 18.04.2 LTS on my laptop. Got a new USB Stick (Samsung) for storing extra files and I am unable to access it.
When I insert it, the folder shows up but when I click on it, it says:
Unable to access Samsung USB
- Error mounting ... Samsung USB: Unknown file system Type 'Exfat'
What do I need to do to be able to access it? Please give advice that an absolute IT beginner can handle :)
Melebius
  • 11,750
LisaK
  • 93
The USB drive was pre-formatted with the exFAT file system. You have two options: You can either format the disk to use a different file system, or you can install the packages that Ubuntu needs to read and write to the exFAT file system.
To format the disk:
  • Open the "Disks" utility (gnome-disk-utility)
  • Select your USB device.
  • In the top right corner, open the options menu and select Format Disk...
    (Choose a quick format for speed and MBR for compatibility.)
  • Now that the disk is formatted, select "create a partition in allocated space" below the map under "Volumes".
  • Set the partition size to max.
  • Name the volume and select a file system. Note the compatibility descriptions with each choice. FAT/FAT16/FAT32 have the most compatibility and will work on Linux, Mac, & Windows.
To add exFAT capability to your system:
  • Open a terminal
    sudo apt update
    sudo apt install exfat-fuse exfat-utils
  • reboot your system
Nmath
  • 12,664
