I read some places that you can just install Docky using apt by default but that doesn't work. Tried adding the repository, but it's one of those that won't update because it's unauthorized or something. Is there a repo that works with Ubuntu 19.04 for Docky?
EDIT: @user535733
> $ sudo add-apt-repository ppa:docky-core/stable [sudo] password:
> This ppa is currently used for builds of release builds of
> docky and plank.  More info:
> https://launchpad.net/~docky-core/+archive/ubuntu/stable Press [ENTER]
> to continue or Ctrl-c to cancel adding it.
> Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease Hit:2
> http://archive.canonical.com/ubuntu cosmic InRelease
> Hit:3 http://us.archive.ubuntu.com/ubuntu disco InRelease
> Hit:4 http://dl.google.com/linux/chrome/deb stable Release
> Hit:5 http://us.archive.ubuntu.com/ubuntu cosmic InRelease
> Get:6 http://security.ubuntu.com/ubuntu disco-security InRelease [97.5
> kB]      Hit:7 http://us.archive.ubuntu.com/ubuntu disco-updates
> InRelease               Hit:8 http://us.archive.ubuntu.com/ubuntu
> cosmic-updates InRelease              Ign:9
> http://ppa.launchpad.net/docky-core/stable/ubuntu disco InRelease
> Hit:11 http://us.archive.ubuntu.com/ubuntu disco-backports InRelease
> Err:12 http://ppa.launchpad.net/docky-core/stable/ubuntu disco Release
> 404  Not Found [IP: 91.189.95.83 80] Reading package lists... Done
> E: The repository 'http://ppa.launchpad.net/docky-core/stable/ubuntu
> disco Release' does not have a Release file. N: Updating from such a
> repository can't be done securely, and is therefore disabled by
> default. N: See apt-secure(8) manpage for repository creation and user
> configuration details.
You know, just you're usual can't update repo error.
The docky-core PPA doesn't have a disco release. Their most current is artful. Change your .list file in /etc/apt/sources.list, or in /etc/apt/sources.list.d/, or look for another, more currently supported PPA.
Update #1:
In terminal...
cd /etc/apt # change directory
grep -i docky sources.list # search for docky
If it finds docky, then:
sudo pico sources.list # edit the file
Locate the line that contains docky
Change disco to artful
control+o, then return # to save the file
control+x # exit the editor
You're done.
If it didn't find docky, then:
cd sources.list.d # change directory
grep -i docky *.list # search again for docky
Note the filename when it finds docky
sudo pico found_filename.list # edit that filename
You're done.
heynnema
  • 73,649
