Is there a way I can remove the rounded borders on the top left and right corners of windows on Gnome Shell? How can I do it?
From the ArchLinux Forum:
edit the css in /usr/share/gnome-shell/theme/gnome-shell.css
(the .panel-corner properties).
The credit goes to the forum user "gimmy". Refer to the original forum in the sources below if you would like to view the entire thread.
Source: ArchLinux Forum - https://bbs.archlinux.org/viewtopic.php?id=138403
For the people who use a custom theme: A better way is to modify the gnome-shell css file of the theme. If you use a gnome-shell.css file with your custom theme, edit the file with a text editor and just add these lines:
.panel-corner {
-panel-corner-radius: 0px;
-panel-corner-background-color: transparent;
-panel-corner-border-width: 0px;
-panel-corner-border-color: transparent;
"Remove Rounded Corners extension" is a good extension but sometimes it bugs with the "User Theme" extension...
- 1,214
- 31
Any easier way to remove rounded corners and have it persist even after theme updates is to use the Remove Rounded Corners extension.
- 41
- 2
There is a package called GNOME Tweak Tool sudo apt-get install gnome-tweak-tool that allows you to make changes to the interface, and install new themes. You can find additional GNOME-Shell themes here, and perhaps other sites as well.
- 1,858
