I've got an external HDD (640 GB), with file system FAT32. I want to change the ownership of it from root (default) to angstrem (my username). The system is mounted to /media/exthdd. I try to do that by a command:
sudo chown -vR angstrem:angstrem /media/exthdd
and after that the system gives me an error:
chown: changing ownership of `/media/exthdd': Operation not permitted
If anybody knows, please tell me, how to change ownership of that HDD?
Angstrem
  • 675
FAT doesn't support file ownership, so you need to specify the owner when you mount the device. You can do this by adding uid and gid options to your mount command.
jpd
  • 1,040
Mounting this way in Ubuntu 18.10 is deprecated, but still works. With a spot of luck your external drive will be mounted as the current user. Please note though that sdb1 may not be the name of your drive.
gvfs-mount -d /dev/sdb1
Jack
  • 4,029
