When I install openssh-server with apt-get install on my ubuntu 18.04.2 LTS server an error occures when kpgk processes the package. The server is a cloud machine with 1 VCPU, 2 GB RAM, 20 GB Disk (4 GB still available).
dpkg --print-architecture: amd64
dpkg --print-foreign-architectures: i386
name -a: Linux [computer-name] 4.15.0-45-generic #48-Ubuntu SMP Tue Jan 29 16:28:13 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Here is the exact command and full output:
apt-get install:
Reading package lists... Done
Building dependency tree
The following packages werde automatically installed and are no longer required:
  linux-image-4.15.0-42-generic linux-modules-4.15.0-42-generic
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed
After this operatoin, 0 B of additional disk space will be used.
Setting up openssh-server (1:7.6p1-4ubuntu0.3) ...
/var/lib/dpgk/info/openssh-server.postinst: 95: /var/lib/dpkg/info/openssh-server.postinst: tempfile: Exec format error
dpkg: error processing package openssh-server (--configure):
  installed openssh-server package post-installation script subprocess returned error exit status 2
  openssh-server
The dpkg status of the package is now "install ok half-configured"
Maintainer is Ubuntu Developers
can someone give me a push in the right direction on how to solve this?`
Thanks
cw24
  • 111
