32
I am running a WordPress website over LEMP stack server on Ubuntu 18.04 on DigitalOcean. WordPress is recommending me to update my PHP to the latest version.
I am running PHP 7.2.17; Please tell me the safest way to update my PHP to the latest version PHP 7.3.
karel
  • 122,292
  • 133
  • 301
  • 332
Open the terminal and type:
sudo add-apt-repository ppa:ondrej/php
sudo apt update
sudo apt install php7.3 # The latest version in this repo for 18.04 and 20.04 is currently php7.4.
The latest version in ppa:ondrej/php for 22.04 is currently php8.2 but php7.4 is also still supported.
php7.3 will be updated automatically when updates become available. Alternatively you can build php7.3 from source in Ubuntu 18.04, but it will not be updated automatically, and it also takes more than an hour to build if you want to test it too.
After installing php7.3 you can show php7.3 modules that can also be installed by running the following command:
apt-cache search php7.3 | grep php7.3
A quick one-line command to install the same packages on php7.3 as php7.2:
sudo apt install $(apt list --installed | grep php7.2- | cut -d'/' -f1 | sed -e 's/7.2/7.3/g')
karel
  • 122,292
  • 133
  • 301
  • 332
From @karel's answer I replace the first command from sudo add-apt-repository ppa:ondrej/php to sudo apt-add-repository ppa:ondrej/php and it works for me. So finally I run:
sudo apt-get update
sudo apt-get install php7.3
