Folks,
I have a Lenovo Legion Y7000 with dual boot system (Win10 and Ubuntu 18.04). The internal wireless card is Realtek 8822be and I have also attached a Panda wireless USB drive (as I was unable to get the internal wireless card working). When I go to Wi-Fi Settings in Ubuntu, I see "No Wi-Fi Adapter Found" for both internal and USB Wi-Fi drives. But the following commands actually show that Ubuntu has detected my Wi-Fi chips:
o-vh@o-vh:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 04ca:7070 Lite-On Technology Corp.
Bus 001 Device 003: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 001 Device 005: ID 0bda:b023 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 148f:5372 Ralink Technology, Corp. RT5372 Wireless Adapter
Also,
o-vh@o-vh:~$ iwconfig
wlp7s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Power Management:on
enp8s0 no wireless extensions.
wlx7cdd90764d5b IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short long limit:2 RTS thr:off Fragment thr:off
Power Management:off
lo no wireless extensions.
which is not clear to me, as it seems that two wireless cards are detected, but I still see two no wireless extensions. messages. Finally, when I run lshw -C network, I see:
*-network
description: Wireless interface
product: RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:07:00.0
logical name: wlp7s0
version: 00
serial: 48:5f:99:b2:fd:e7
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=r8822be driverversion=4.15.0-50-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:143 ioport:4000(size=256) memory:a4300000-a430ffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0
bus info: pci@0000:08:00.0
logical name: enp8s0
version: 15
serial: e8:6a:64:c1:75:66
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.88.187 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:17 ioport:3000(size=256) memory:a4204000-a4204fff memory:a4200000-a4203fff
*-network DISABLED
physical id: 1
bus info: usb@1:1
logical name: wlx7cdd90764d5b
serial: 7c:dd:90:76:4d:5b
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rt2800usb driverversion=4.15.0-50-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11
Note that for the USB Wi-Fi I see *-network DISABLED while I don't see this for the Realtek Wi-Fi.
Can anyone give me some hints on what the problem is and how I can fixed the "No Wi-Fi Adapter Found" issue? I appreciate your help very much!
I have tried many of the approaches suggested for similar (but not identical) problems without any success.
