I just installed Ubuntu Studio 19.04 on an old Acer Aspire E1-510. It seemed to be working mostly fine, but it seems that upon trying to suspend, shutdown, or restart the system, it would get stuck on a black screen and I would have to force shut down by long pressing the power button. I thought I might've messed up the system when I was trying to get polybar and conky to work, so I reinstalled from scratch, but the problem still persists.
Please help me out here.
buggy
  • 33
I have a machine identical to yours. It has the same problem, and none of my other machines (two Dells and a Thinkpad) have this issue, so I have always suspected it's a hardware/BIOS incompatibility issue.
Try blacklisting dw_dmac, and dw_dmac_core, then adding the following code to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=1"
Kulfy
  • 18,154
me is me
  • 437
I can confirm the same issue on acer swift 3/ubuntu 19 with bios ugpraded to latest version ~ may 2019.
Additionally the OS freezes up quite a bit for a split second or two, every few mins, due to picue sending over too many requests to the cpu or something of that sort (issue described here). I haven't tried implementing this solution on my machine, since i was told it could screw up the whole machine by not allowing it to boot from the ssd.
