I tried to install libjasper-dev and libpng12 for opencv but I'm getting this error:
E: Unable to locate package libjasper-dev E: Unable to locate package libpng12
I also tried installing libpng16 but still I was getting the same error. How can I solve this problem?
Jay Lakhupota
Alternative solution:
  1. Add the following to etc/apt/source.list - this is a document you can navigate to in file manager
### Preface with a comment is optional
### Helps to remember why something was added to the list later on
### Added for libjasper-dev
deb http://security.ubuntu.com/ubuntu xenial-security main
  1. Update the package index
sudo apt-get update
  1. Install libjasper-dev
sudo apt-get install libjasper-dev
P.S. You may want to keep in mind that this library may be outdated or not intended for your version of Linux, so there's always a possibility that what you want it for will not work properly or stop working eventually.
Sabidos
To install libjasper-dev using below:
Add the following line to /etc/apt/sources.list:
deb http://ftp.fau.de/trinity/trinity-builddeps-r14.0.0/ubuntu/ bionic main
Install GPG key of the repository:
# sudo apt-key adv --keyserver keyserver.quickbuild.io --recv-keys F5CFC95C
Update the package index:
# sudo apt-get update
Install libjasper-dev deb package:
# sudo apt-get install libjasper-dev
Reference https://ubuntu.pkgs.org/18.04/trinity-r14-builddeps-i386/libjasper-dev_1.900.1-debian1-2.5ubuntu18.04.0+5_i386.deb.html
To install libpng12 refer below link
E: Package 'libpng12-0' has no installation candidate [ubuntu 16.10 Gnome]
You can install it:
apt-get install libpng-dev
You can download the source code from here and build:
$ wget https://www2.mmm.ucar.edu/wrf/OnLineTutorial/compile_tutorial/tar_files/jasper-1.900.1.tar.gz
$ wget https://www2.mmm.ucar.edu/wrf/OnLineTutorial/compile_tutorial/tar_files/libpng-1.2.50.tar.gz
And export the library path as follow:
$ export JASPERLIB=/home/user/build/grib2/lib
$ export JASPERINC=/home/user/build/grib2/include
