On Saturday (May 18) I started one of my VMs (running Ubuntu 18.04 Server).
To my surprise, the VM almost immediately attempted to connect to d16r8ew072anqo.cloudfront.net:80,
something that I have never seen before--it's a pretty "pristine" installation of Ubuntu,
with no custom apt repositories, and just a few packages installed.
It had never connected to anything suspicious before--mostly to Ubuntu and Snap domains.
(I use Little Snitch to monitor network traffic so I see connections in real time
and can deny them as well.)
I spent some time trying to figure out what happened
and I believe I narrowed it down to unattended-upgrades installing security patches.
Specifically, when I manually reinstalled intel-microcode:amd64 package I was able to
reproduce the strange connection to CloudFront (although it might have been
just a coincidence).
Then, on Monday, I wanted to document the issue in case something similar happens again, but to my surprise I couldn't reproduce the strange connection anymore.
And the only observable difference on Monday was that the output from
sudo apt-get install --reinstall intel-microcode:amd64 [1] did't have the Ign:1 line.
I searched the web, including http://archive.ubuntu.com/ubuntu, grep-ed
the VM's disk, checked the DNS records of misc. ubuntu.com subdomains,
tried wget-ting different URLs to find a redirect to the suspicious domain--but I couldn't find any clue about the strange connection to CloudFront.
My question is: does anyone know what happened, or at least noticed the same connection in their logs?
(By the way, I'm aware of one example where the Ubuntu team used CloudFront to relieve their servers: MD5 mismatch on my 12.04 ISO, what is going on? --so I'm hoping that maybe this is a similar case?)
[1]:
$ sudo apt-get install --reinstall intel-microcode:amd64
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 1,801 kB of archives.
After this operation, 0 B of additional disk space will be used.
Ign:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 intel-microcode amd64 3.20190514.0ubuntu0.18.04.2
Get:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 intel-microcode amd64 3.20190514.0ubuntu0.18.04.2 [1,801 kB]
Fetched 1,801 kB in 20s (89.2 kB/s)
(Reading database ... 107477 files and directories currently installed.)
Preparing to unpack .../intel-microcode_3.20190514.0ubuntu0.18.04.2_amd64.deb ...
Unpacking intel-microcode (3.20190514.0ubuntu0.18.04.2) over (3.20190514.0ubuntu0.18.04.2) ...
Setting up intel-microcode (3.20190514.0ubuntu0.18.04.2) ...
update-initramfs: deferring update (trigger activated)
intel-microcode: microcode will be updated at next boot
Processing triggers for initramfs-tools (0.130ubuntu3.7) ...
update-initramfs: Generating /boot/initrd.img-4.15.0-50-generic
