16
Every time starting the machine, I run the following program:
$ cat start.sh
#! /bin/bash
google-chrome &> /dev/null &
lantern &> /dev/null &
xdg-open . &> /dev/null &
emacs &> /dev/null  &
code ~/Programs/ &> /dev/null &
xdg-open ~/Reference/topic_regex.md &> /dev/null &
Cumbersome &> /dev/null &... How could I shorten the logic?
Melebius
  • 11,750
Wizard
  • 2,951
5 Answers5
17
The part &> /dev/null means output redirection. You can redirect multiple commands to the same file by grouping them into a block:
#! /bin/bash
google-chrome &
lantern &
xdg-open . &
emacs  &
code ~/Programs/ &
} &> /dev/null
The same thing, however, cannot be used to start individual commands in the background (&). Putting & after the block would mean running the whole block as a single script in the background.
Melebius
  • 11,750
14
I wrote a function and put it into my .bashrc to run things detached from my terminal:
detach ()
    ( "$@" &> /dev/null & )
... and then:
detach google-chrome
detach xdg-open ~/Reference/topic_regex.md
And because I'm lazy, I also wrote a shortcut for xdg-open:
xo ()
    for var in "$@"; do
        detach xdg-open "$var";
    done
Because xdg-open expects exactly one argument, the function xo iterates over all given arguments and calls xdg-open for each one separately.
This allows for:
xo . ~/Reference/topic_regex.md
PerlDuck
  • 13,885
You could redirect the output for all subsequent commands with
exec 1>/dev/null
exec 2>/dev/null
ohno
  • 833
I created a special file like /dev/null with a shorter path to shorten the redirection. I used /n as the new file’s path:
sudo mknod -m 0666 /n c 1 3
This way you can shorten the individual lines to e.g.:
google-chrome &>/n &
Source: How to create /dev/null?
dessert
  • 40,956
You could create a loop and give it the commands as arguments:
for i in google-chrome "xdg-open ." "code ~/Programs/"; do
  $i &
done &>/dev/null
Note that this way exactly as with the subshell approach with curly braces it’s possible to sum up the outputs and redirect all of them at once.
dessert
  • 40,956
