I am trying to install Ubuntu 18.04 on an old HP DL360-G5 server. The server is equipped with two Broadcom NetXtreme BCM5708 ethernet controllers. I have one of the ethernet ports on my machine connected to my switch and the lights on the port show connection and activity.
When I make it to the step 4 of the Ubuntu install process (via USB drive) I am asked to configure the network interfaces. Two interfaces are shown ("enp0s3" & "enp0s5"). Both interfaces fail to obtain an IP address using DHCP and also fail when an IP address is provided manually.
From the installation page there is an option to create a "bond", I am not sure if this is necessary to simple get a connection to the internet through either one of my network interfaces. Finally after some research online I see that there might be the requirement of installing the BNX2 driver.
So here are my questions:
  1. Is there something obvious that I am missing here, perhaps I need to create a bond in order to obtain an IP address?
  2. Does the fact that the two network interfaces show up in the Ubuntu install mean that they are configured correctly and should work if provided the correct configuration?
  3. Do I need to install the BNX2 driver, and if so how do I do this prior to arriving at the network interface part of the Ubuntu installation?
MattC
  • 111
