how can i boot the iso files from the raid 1 in grub2?
i have a raid 1 (intel raid, ntfs) with some boot iso files. once i selected the entry in the grub2 boot menu say ubuntu iso, it booted and the splash screen shown, but a few seconds later it showed "/iso/xxx.iso" not found and stopped, which "/iso/xxx.iso" is the real path to the iso file on the raid 1.
here's what the entry looks like:
set isofile="/iso/linux.iso"
search --fs-uuid --no-floppy --set=root RAID_1_UUID
loopback loop (${root})$isofile
i also tried to run the above lines in the grub2 command prompt and i could see the file, so both set root and loopback work but i think the os (inside the iso) couldnt find the iso to load the kernel, perhaps they cant read the raid at this point. i booted another iso but it prompted "cannot mount /dev/sdd" and "cannot mount /dev/sde" (the raid partitions), and gparted iso showed a message that i should mount the raid before loading.
although i finally managed to boot it by adding "toram" to the kernel parameter, i am unable to boot other iso files like gparted, etc
so what's the proper way to do it? i have googled but didnt find anything related to booting iso files stored on the raid 1.
thanks
edit, for example, this entry works before the raid1 is created but now will show "cannot find //iso/Porteus-CINNAMON-v4.0-x86_64.iso" during boot (note the double slashes there)
menuentry 'Porteus CINNAMON v4.0' {
set isofile="/iso/Porteus-CINNAMON-v4.0-x86_64.iso"
search --fs-uuid --no-floppy --set=root $raid_uuid
linux (loop)/boot/syslinux/vmlinuz from=$isofile copy2ram noswap noauto login=guest quiet timezone=Asia/Hong_Kong kmap=us
initrd (loop)/boot/syslinux/initrd.xz
boot
