I a new Linux user and this is my second question. Here is my problem:
I just got a new computer (Lenovo Thinkpad E590 i7-8565) and I successfully installed Ubuntu 18.04 LTS alongside Windows 10 Pro. So, I have both OS available when I boot and I made a third NTFS partition where I can store my files which can be accessed on Linux and on Windows 10.
Sometimes when I boot on Ubuntu, I got this showing up:
Output for $ cat /var/log/kern.log:
mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
I got stuck between this screen and the Ubuntu loading screen.
My only option is to press the power button and to restart my computer again. After 2 or 3 tries, my Ubuntu finally starts (but those errors are still showed)
I checked the temperature of my CPU right after and everything seems to by normal.
Output for $ sensors:
thinkpad-isa-0000
Adapter: ISA adapter
fan1:           0 RPM
coretemp-isa-0000
Package id 0:  +45.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:        +43.0°C  (high = +100.0°C, crit = +100.0°C)
Core 1:        +44.0°C  (high = +100.0°C, crit = +100.0°C)
Core 2:        +45.0°C  (high = +100.0°C, crit = +100.0°C)
Core 3:        +44.0°C  (high = +100.0°C, crit = +100.0°C)
I already tried that fix here: https://github.com/erpalma/throttled, but it didn't work for my Lenovo E590.
Thank you very much in advance for your help.
PS.: I had an issue that I solved a few weeks ago where my motherboard made a very hard and long beep. The beep started when I did boot my computer and ended when I left GRUB. This was an issue with the kernel that I had to update. So now, my kernel is 5.0.7-generic. As a new Linux user, I don't really know if there is a correlation between this and my current issue. So I just put it here just in case.
EDIT: I always update and upgrade my Ubuntu periodically and I didn't have this issue since a while. I suppose this is due to a particular update. So I leave this topic unsolved in the case someone else has the same problem.
Bravo2bad
  • 327
  • 18
I update my kernel regularly and this issues never occurred since a while, so I suppose this issue has been fixed in one of those updates.
So I'll close this post.
Bravo2bad
  • 327
  • 18
