Any time I try to install anything or run apt update, I get this error:
E: The repository 'http://ppa.launchpad.net/moonlight-team/pinta/ubuntu bionic Release' does not have a Release file.
Oli
  • 299,380
Looking deeper, going through ./pool/main/p/pinta/ you can see this repos is ancient:
pinta_0.5+dfsg-1~dhx1_all.deb   2010-11-03 20:27
While I'm sure you can download the packages manually, I would suggest this is a dead repo and should be left well alone. The "official" pinta-maintainers/pinta-stable repo is in a similar state, last updated in 2015.
Pinta itself seems a bit abandoned (last release was 2015) and while it still works (I have it installed) the packaging for it, how it links into the rest of the system, needs regular maintenance as Ubuntu changes. Your best bet is probably installing it from a Flatpak package. These have the advantage that they get bundled with most of their requirements so should keep working indefinitely, often to a fault.
Oli
  • 299,380
