I'm trying to install an out of tree module for my gnuradio and I'm following a youtube video https://www.youtube.com/watch?v=BW8o9ZgFJ5I&t=540s. However once I get to testing the code it keeps finding errors that I can't seem to find.
It shows me this when I put make test:
ubuntu@ubuntu:~/gr-NRZI_decode/build$ make test
Running tests...
Test project /home/ubuntu/gr-NRZI_decode/build
Start 1: test_NRZI_decode
1/2 Test #1: test_NRZI_decode ................. Passed 0.02 sec
Start 2: qa_square_ff
2/2 Test #2: qa_square_ff .....................***Failed 0.46 sec
50% tests passed, 1 tests failed out of 2
Total Test time (real) = 0.49 sec
The following tests FAILED:
2 - qa_square_ff (Failed)
Errors while running CTest
Makefile:85: recipe for target 'test' failed
make: *** [test] Error 8
They when I try to zero in on the problem with ctest -V -R qa_square_ff I get this:
UpdateCTestConfiguration from :/home/ubuntu/gr-NRZI_decode/build/DartConfiguration.tcl
Constructing a list of tests
Done constructing a list of tests
Updating test list for fixtures
Added 0 tests to meet fixture requirements
Checking test dependency graph...
Checking test dependency graph end
test 2
2: Test command: /bin/sh "/home/ubuntu/gr-NRZI_decode/build/python/qa_square_ff_test.sh"
2: Test timeout computed to be: 9.99988e+06
2: E
2: ======================================================================
2: ERROR: test_001_square_ff (__main__.qa_square_ff)
2: ----------------------------------------------------------------------
2: Traceback (most recent call last):
2: File "/home/ubuntu/gr-NRZI_decode/python/qa_square_ff.py", line 40, in test_001_square_ff
2: self.tb.connect(src,sqr)
2: File "/usr/lib/python2.7/dist-packages/gnuradio/gr/hier_block2.py", line 47, in wrapped
2: func(self, src, src_port, dst, dst_port)
2: File "/usr/lib/python2.7/dist-packages/gnuradio/gr/hier_block2.py", line 110, in connect
2: self.primitive_connect(*args)
2: File "/usr/lib/python2.7/dist-packages/gnuradio/gr/runtime_swig.py", line 5307, in primitive_connect
2: return _runtime_swig.top_block_sptr_primitive_connect(self, *args)
2: ValueError: itemsize mismatch: vector_source_f1:0 using 4, square_ff1:0 using 1
2:
2: Ran 1 test in 0.000s
2:
2: FAILED (errors=1)
1/1 Test #2: qa_square_ff .....................***Failed 0.19 sec
0% tests passed, 1 tests failed out of 1
Total Test time (real) = 0.19 sec
Here is my code for qa_square_ff.py:
from gnuradio import gr, gr_unittest
from gnuradio import blocks
import NRZI_decode_swig as NRZI_decode
class qa_square_ff (gr_unittest.TestCase):
def setUp (self):
self.tb = gr.top_block ()
def tearDown (self):
self.tb = None
def test_001_square_ff(self):
src_data=(1,2,3,4,5)
expected_data=(1,4,9,16,25)
src=blocks.vector_source_f(src_data)
sqr=NRZI_decode.square_ff()
dst=blocks.vector_sink_f()
self.tb.connect(sqr,dst)
self.tb.run ()
result_data=dst.data()
self.assertCharTuplesAlmostEqual(expected_data,result_data,6)
# check data
if __name__ == '__main__':
gr_unittest.run(qa_square_ff, "qa_square_ff.xml")
