I am new to Ubuntu (to Linux in general) and while I was installing Latex through the terminal:
sudo apt-get install texlive-full
I had this error message:
and the full result of the previous command is:
Reading package lists... Done
Building dependency tree
 texlive-full : Depends: asymptote but it is not going to be installed
                Depends: biber but it is not going to be installed
                Depends: cm-super (>= 0.3.3-3) but it is not going to be installed
                Depends: context but it is not going to be installed
                Depends: dvipng but it is not going to be installed
                Depends: feynmf but it is not going to be installed
                Depends: fragmaster but it is not going to be installed
                Depends: latex-cjk-all (>= 4.6.0+cvs20060714-2) but it is not going to be installed
                Depends: latexmk but it is not going to be installed
                Depends: lmodern (>= 0.93.3) but it is not installable
                Depends: prerex (> 6.5.3-1) but it is not going to be installed
                Depends: purifyeps but it is not going to be installed
                Depends: tex-gyre but it is not going to be installed
                Depends: texinfo (>= 4.8)
                Depends: texlive-base (>= 2018.20190227) but it is not installable
                Depends: texlive-bibtex-extra (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-binaries (>= 2018.20180416) but it is not installable
                Depends: texlive-extra-utils (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-font-utils (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-fonts-extra (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-fonts-extra-doc (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-fonts-extra-links (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-fonts-recommended (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-fonts-recommended-doc (>= 2018.20190227) but it is not installable
                Depends: texlive-formats-extra (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-games (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-humanities (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-humanities-doc (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-arabic (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-chinese (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-cjk (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-cyrillic (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-czechslovak (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-english (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-european (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-french (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-german (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-greek (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-italian (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-japanese (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-korean (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-other (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-polish (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-portuguese (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-lang-spanish (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-latex-base (>= 2018.20190227) but it is not installable
                Depends: texlive-latex-base-doc (>= 2018.20190227) but it is not installable
                Depends: texlive-latex-extra (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-latex-extra-doc (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-latex-recommended (>= 2018.20190227) but it is not installable
                Depends: texlive-latex-recommended-doc (>= 2018.20190227) but it is not installable
                Depends: texlive-luatex (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-metapost (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-metapost-doc (>= 2018.20190227) but it is not installable
                Depends: texlive-music (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-pictures (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-pictures-doc (>= 2018.20190227) but it is not installable
                Depends: texlive-plain-generic (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-pstricks (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-pstricks-doc (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-publishers (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-publishers-doc (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-science (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-science-doc (>= 2018.20190227) but it is not going to be installed
                Depends: texlive-xetex (>= 2018.20190227) but it is not going to be installed
                Depends: tipa (>= 2:1.2-2.1) but it is not going to be installed
                Depends: vprerex (> 6.5.3-1) but it is not going to be installed
Remark: When I was installing Latex in the first time it was going well, then I lost my connexion and stopped the task, so when I went to it the second time the problem began.
EDIT: I was trying to see what is there in the two comments, for the first one, the problem seems to don't be about the universe repository, because when I made this command
sudo add-apt-repository universe
I have got
'universe' distribution component is already enabled for all sources.
for the second comment, I have tried all that was written in the answers, but no one seems to be working with me, for example
dpkg --get-selections | grep hold
give nothing, updating, upgrading and making autoremove and so also did,' solve the problem, I have also installed synaptic, but in it, there is nothing in the broken part, I am really lost with this problem, thanks in advance
