How to setup of Raspberry Pi 3 B+ onboard WiFi for Ubuntu Server 18.04? In particular, with netplan?
Existing answers, such as "How to use onboard wifi on Raspberry Pi 3 with Ubuntu Server 16.04?", no longer seem to apply since /etc/network/interfaces states that netplan has replaced ifupdown.
# ifupdown has been replaced by netplan(5) on this system. See
# /etc/netplan for current configuration.
This is a clean install of the Ubuntu Server image for Raspberry Pi 3.
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 18.04.2 LTS
Release: 18.04
Codename: bionic
##### kernel ############################
Linux 4.15.0-1034-raspi2 #36-Ubuntu SMP PREEMPT Fri Apr 5 06:21:41 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
According to Ubuntu Wiki RaspberryPI the needed packages should already be in place.
Since 18.04.2 the linux-firmware and linux-firmware-raspi2 packages now contain the necessary files for the built-in WiFi on the Pi 3B and 3B+.
sudo lshw -C network
*-network:0 DISABLED
description: Wireless interface
physical id: 2
logical name: wlan0
serial: b8:27:eb:69:f2:3b
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=brcmfmac driverversion=7.45.18 firmware=01-6a2c8ad4 multicast=yes wireless=IEEE 802.11
*-network:1
description: Ethernet interface
physical id: 3
logical name: eth0
serial: b8:27:eb:3c:a7:6e
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=lan78xx driverversion=1.0.6 duplex=full ip=172.16.76.7 link=yes multicast=yes port=MII speed=1Gbit/s
Netplan.io provides some general Netplan configuration examples.
To configure netplan, save configuration files under
/etc/netplan/with a.yamlextension (e.g./etc/netplan/config.yaml), then runsudo netplan apply.
... yet, no guideance specific to a RaspberryPi. ...in particular, with respect to the existing /etc/netplan/50-cloud-init.yaml file on the RaspberryPi Ubuntu Server install.
##### Netplan config ####################
[/etc/netplan/50-cloud-init.yaml]
# This file is generated from information provided by
# the datasource. Changes to it will not persist across an instance.
# To disable cloud-init's network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
version: 2
ethernets:
eth0:
dhcp4: true
match:
macaddress: <MAC 'eth0' [IF1]>
set-name: eth0
So, given the use of netplan and default generated .yaml file. How should one add a WiFi network SSID and password? And leave the existing wired ethernet in place?
