My machine crashed around 07:03 and return to the login interface.
Here are the xsession-errors log
the short excerpt
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /home/gaowei/.config/SogouPY/punctures.ini failed.
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /usr/share/fcitx-sogoupinyin/SogouInput/sgim_charvalid.bin
May 14 07:03:43 alpha gnome-session[2538]: gnome-session-binary[2538]: CRITICAL: We failed, but the fail whale is dead. Sorry.
May 14 07:03:43 alpha gnome-session-binary[2538]: Unrecoverable failure in required component org.gnome.Shell.desktop
May 14 07:03:43 alpha gnome-session[2538]: gnome-session-binary[2538]: WARNING: App 'org.gnome.Shell.desktop' respawning too q
May 14 07:03:43 alpha gnome-session[2538]: gnome-session-binary[2538]: WARNING: App 'org.gnome.Shell.desktop' exited with code
The full excerpt:
May 14 07:03:45 alpha systemd[2474]: Stopping Virtual filesystem service - disk device monitor...
May 14 07:03:43 alpha systemd[2474]: Started Sound Service.
May 14 07:03:43 alpha pulseaudio[8833]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.AccessDenied: Rejected send message, 2 matched rules; type="method_call", sender=":1.594" (uid=1000 pid=8833 comm="/usr/bin/puls
May 14 07:03:43 alpha pulseaudio[8833]: E: [pulseaudio] module-alsa-card.c: Failed to open mixer for jack detection
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /usr/share/fcitx-sogoupinyin/SogouInput/sgim_urlGuide.bin failed.
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /usr/share/fcitx-sogoupinyin/SogouInput/sgim_tip.bin failed.
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: check false, remove P
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /home/gaowei/.config/SogouPY/sgim_privilege.bin failed.
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: check false, remove A
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /home/gaowei/.config/SogouPY/sgim_phrases.bin failed.
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: check false, remove U
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /home/gaowei/.config/SogouPY/sgim_usr_v3_ext.bin failed.
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: check false, remove C
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file failed.
May 14 07:03:43 alpha /usr/lib/gdm3/gdm-x-session[2523]: open file /usr/share/fcitx-sogoupinyin/SogouInput/sgim_charvalid.bin failed.
May 14 07:03:43 alpha gnome-session[2538]: gnome-session-binary[2538]: CRITICAL: We failed, but the fail whale is dead. Sorry....
May 14 07:03:43 alpha gnome-session[2538]: gnome-session-binary[2538]: WARNING: App 'org.gnome.Shell.desktop' respawning too quickly
May 14 07:03:43 alpha gnome-session[2538]: gnome-session-binary[2538]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
May 14 07:03:43 alpha gnome-shell[8819]: Failed to create backend: Unable to open display ':0'
May 14 07:03:43 alpha pulseaudio[8833]: W: [pulseaudio] pid.c: Stale PID file, overwriting.
May 14 07:03:43 alpha gnome-session[2538]: gnome-session-binary[2538]: WARNING: App 'org.gnome.SettingsDaemon.Keyboard.desktop' exited with code 1
May 14 07:03:43 alpha systemd[2474]: Starting Sound Service...
May 14 07:03:43 alpha systemd[2474]: Stopped Sound Service.
May 14 07:03:43 alpha systemd[2474]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
Is that the problem of my input method of sougou pinyin?
The problem started on Mar 22, the detailed log
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.10
Release: 18.10
Codename: cosmic
