With the command below, I thought I had rescued the content of my broken Android phone:
adb pull /dev/block/mmcblk0p28 mmcblk0p28.img
Unfortunately my attempt to mount it on Ubuntu fails:
sudo mount -o loop mmcblk0p28.img /mnt/
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/loop20, missing codepage or helper program, or other error.
I think it is ext4. Photorec (set up for ext) successfully outputs all of my files, but with random filenames so I still want to mount the image.
After reading the highest-voted answer at a similar question I tried fdisk but it does not show partition info, probably because I pulled only a single partition:
$ sudo fdisk -lu mmcblk0p28.img
Disk mmcblk0p28.img: 6.2 GiB, 6654066688 bytes, 12996224 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Another answer suggests losetup, when I run sudo losetup -Pf mmcblk0p28.img it does not output anything nor does it mount anything.
What is the correct command?
Or is my image somehow corrupt?
