when I set cpu frequency range with this command:
sudo cpupower frequency-set -d 500MHz -u 2700MHz
the frequency range is succesfully set to these values, but when I reboot and do:
sudo cpupower frequency-info
i notice that the frequency range is set to other values. This is the output:
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 500 MHz - 2.70 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 1.08 GHz and 1.08 GHz.
The governor "powersave" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 998 MHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
Can anyone help me make it not reset? Thanks!
