I am trying to install Packet Tracer on Ubuntu 19.04, but it gives me the error below when I try to launch it:
./PacketTracer7: ./libcrypto.so.1.0.0: no version information available (required by ./PacketTracer7)
But when I try to install libssl1.0.0 I get the following error:
**Reading package lists... Done
Building dependency tree
Package libssl1.0.0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source**
**E: Package 'libssl1.0.0' has no installation candidate**
I also collected a debug for this:
Reading symbols from PacketTracer7...
(No debugging symbols found in PacketTracer7)
(gdb) run
Starting program: /opt/pt/bin/PacketTracer7
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffeda96700 (LWP 2775)]
[New Thread 0x7fffece7a700 (LWP 2776)]
[New Thread 0x7fffa7ffd700 (LWP 2778)]
Thread 1 "PacketTracer7" received signal SIGSEGV, Segmentation fault.
0x00000000034602dc in CDeviceTypesBox::CDeviceTypesBox(QVector<SDeviceTypes_t*>, QWidget*, char const*, QFlags<Qt::WindowType>) ()
(gdb) where
#0  0x00000000034602dc in CDeviceTypesBox::CDeviceTypesBox(QVector<SDeviceTypes_t*>, QWidget*, char const*, QFlags<Qt::WindowType>) ()
#1  0x0000000003473201 in CNetworkComponentBox::CNetworkComponentBox(QWidget*, char const*, QFlags<Qt::WindowType>) ()
#2  0x0000000002e9ba0a in Ui_CAppWindowBase::setupUi(QMainWindow*) ()
#3  0x0000000002e96b26 in CAppWindow::CAppWindow(QWidget*, char const*, QFlags<Qt::WindowType>) ()
#4  0x000000000341c801 in oldMain(int, char**) ()
#5  0x00007ffff406cb6b in __libc_start_main (main=0x541620 <main>, argc=1,
    argv=0x7fffffffdf48, init=<optimized out>, fini=<optimized out>,
    rtld_fini=<optimized out>, stack_end=0x7fffffffdf38)
    at ../csu/libc-start.c:308
#6  0x000000000054ad79 in _start ()
Thanks in advance for helping me. And again, excuse my lack of technical knowledge to explain this issue.
gmelodie
  • 195
tierianoob
You can try downloading one from 18.10 repository, since it's yet to be available on 19.04.
wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl1.0/libssl1.0.0_1.0.2n-1ubuntu6.2_amd64.deb
sudo dpkg -i libssl1.0.0_1.0.2n-1ubuntu6.2_amd64.deb
Liso
  • 15,677
I ran into some trouble getting PT to run on Ubuntu 19.04 and after a bit of research it looks like not only is the libpng12 package required but it needs further customization due to /lib being a symlink to /usr/lib now. While I appreciate the folks dropping links to custom .deb packages I wanted to roll my own
Assumes PacketTracer 7.2.2 has already been installed to /opt/pt
#create dir to hold libpng12
sudo mkdir /opt/pt/libpng
cd /opt/pt/libpng
#obtain official package
sudo wget http://security.ubuntu.com/ubuntu/pool/main/libp/libpng/libpng12-0_1.2.54-1ubuntu1.1_amd64.deb .
#extract package
sudo dpkg-deb -x libpng12-0_1.2.54-1ubuntu1.1_amd64.deb ./libpng12
#Original package structure
libpng12/
├── lib
│   └── x86_64-linux-gnu
│       ├── libpng12.so.0 -> libpng12.so.0.54.0
│       └── libpng12.so.0.54.0
└── usr
    ├── lib
    │       └── libpng12.so.0 -> /lib/x86_64-linux-gnu/libpng12.so.0
    └── share
        └── doc
            └── libpng12-0
                ├── ANNOUNCE
                ├── changelog.Debian.gz
                ├── copyright
                ├── KNOWNBUG
                ├── libpng-1.2.54.txt.gz
                ├── README.Debian
                ├── README.gz
                └── TODO
#export package detail
sudo dpkg-deb -e libpng12-0_1.2.54-1ubuntu1.1_amd64.deb ./libpng12/DEBIAN
#remove symlink from /usr/lib
sudo rm ./libpng12/usr/lib/x86_64-linux-gnu/libpng12.so.0
#move all contents from /lib to /usr/lib
sudo mv ./libpng12/lib/x86_64-linux-gnu/* ./libpng12/usr/lib/x86_64-linux-gnu/
#build package
sudo dpkg-deb -b ./libpng12 libpng12-0_1.2.54_amd64_custom.deb
#install custom package
sudo apt install ./libpng12-0_1.2.54_amd64_custom.deb
Kulfy
  • 18,154
Vic
