I think this folder was probably created by accident at some point, but I can't ls or cd to it to check.
Things I have tried:
ls '-F'
ls "-F"
ls \-F
ls \\\-F
ls \\-F
and the cd equivalents
ls '-F'
ls "-F"
ls \-F
ls \\\-F
ls \\-F
You can do it this way:
ls -lah -- -F
The -- denotes the end of options for the command, same will work with cd and even rm.
cd -- -F
and
rm -r -- -F
You can always specify the file as absolute or relative path instead of just the file name.
The simplest way is to just prefix it with a ./ to indicate it's in your current directory and avoid having the first character of the argument being a - that causes it to be treated as option/flag:
ls ./-F
This should work with basically every command that expects a file name or path as argument, even those which do not support the use of -- as argument separator.
