All of a sudden, neither the pointer nor the return key on my laptop is working in the 16.04 GUI. All the other keys work just fine, as far as I can tell. And the return key does work at the shutdown/restart/suspend/lock prompt (which I get by pressing and holding the power button).
The return key works just fine at the kernel’s “unlock sdaX_crypt” prompt, and at the root shell prompt in recovery mode.
Most of the “pointer not working” troubleshooting guides involve typing stuff in the terminal, which I can’t get to because the return key isn’t working.
How to go about troubleshooting this from the root shell prompt??
Never figured out the cause of my problem, but FWIW this is what worked: Plug in a USB mouse, but not a USB keyboard. This rendered the touchpad and return key temporarily functional. Then edit grub as described in the second solution here:
Edit /etc/default/grub to replace:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
with
GRUB_CMDLINE_LINUX_DEFAULT="i8042.reset quiet splash"
Save the file and then update grub using
sudo update-grub command
Then restart the system.
