Boot Info Script 0.61 [1 April 2012]
============================= Boot Info Summary: ===============================
=> Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
in partition 85 for .
sda1: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista/7: NTFS
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda2: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files:
sda3: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files:
sda4: __________________________________________________________________________
File system: Extended Partition
Boot sector type: Unknown
Boot sector info:
sda5: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 18.04.2 LTS
Boot files: /boot/grub/grub.cfg /etc/fstab
sda6: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda7: __________________________________________________________________________
File system: vfat
Boot sector type: FAT32
Operating System:
Boot files: /efi/BOOT/fbx64.efi /efi/ubuntu/fwupx64.efi
/efi/ubuntu/grubx64.efi /efi/ubuntu/mmx64.efi
/efi/ubuntu/shimx64.efi
sda8: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 1,026,048 163,896,156 162,870,109 7 NTFS / exFAT / HPFS
/dev/sda2 163,897,344 164,911,103 1,013,760 27 Hidden NTFS (Recovery Environment)
/dev/sda3 166,756,352 874,369,023 707,612,672 7 NTFS / exFAT / HPFS
/dev/sda4 874,371,070 976,771,071 102,400,002 5 Extended
/dev/sda5 874,371,072 913,430,527 39,059,456 83 Linux
/dev/sda6 913,432,576 921,243,647 7,811,072 82 Linux swap / Solaris
/dev/sda7 * 921,245,696 922,220,543 974,848 ef EFI (FAT-12/16/32)
/dev/sda8 922,222,592 976,771,071 54,548,480 83 Linux
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/loop0 squashfs
/dev/loop1 squashfs
/dev/loop2 squashfs
/dev/loop3 squashfs
/dev/loop4 squashfs
/dev/loop5 squashfs
/dev/loop6 squashfs
/dev/loop7 squashfs
/dev/sda1 B0C83C75C83C3BC2 ntfs
/dev/sda2 6E0C2CDD0C2CA257 ntfs
/dev/sda3 F6C668AEC66870B3 ntfs New Volume
/dev/sda5 2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede ext4
/dev/sda6 ef82a317-ac35-4498-a65c-8d6469f4ab7a swap
/dev/sda7 3E95-F2AC vfat
/dev/sda8 94281f85-1db7-4aba-a334-5074acb2214a ext4
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda5 / ext4 (rw,relatime,errors=remount-ro)
/dev/sda8 /home ext4 (rw,relatime)
=========================== sda5/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos5'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos5 --hint-efi=hd0,msdos5 --hint-baremetal=ahci0,msdos5 2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede
else
search --no-floppy --fs-uuid --set=root 2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
set timeout=0
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 44,0,30,0; then
clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=1
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.18.0-18-generic root=UUID=2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede ro quiet splash $vt_handoff
initrd /boot/initrd.img-4.18.0-18-generic
submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede' {
menuentry 'Ubuntu, with Linux 4.18.0-18-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.18.0-18-generic-advanced-2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 4.18.0-18-generic ...'
echo 'Loading initial ramdisk ...'
menuentry 'Ubuntu, with Linux 4.18.0-18-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.18.0-18-generic-recovery-2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.18.0-18-generic root=UUID=2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede ro recovery nomodeset
menuentry 'Ubuntu, with Linux 4.18.0-15-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.18.0-15-generic-advanced-2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 4.18.0-15-generic ...'
linux /boot/vmlinuz-4.18.0-15-generic root=UUID=2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede ro quiet splash $vt_handoff
initrd /boot/initrd.img-4.18.0-15-generic
menuentry 'Ubuntu, with Linux 4.18.0-15-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.18.0-15-generic-recovery-2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.18.0-15-generic root=UUID=2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry "windows 10 (loader) (on /dev/sda1)"{
insmod part_msdos
insmod ntfs
set root='(hd0,msdos1)'
chainloader +1
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda5/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda5 during installation
UUID=2fbabe25-d094-4d4a-8d6a-0dcbf2dd7ede / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda7 during installation
#UUID=3E95-F2AC /boot/efi vfat umask=0077 0 1
# /home was on /dev/sda8 during installation
UUID=94281f85-1db7-4aba-a334-5074acb2214a /home ext4 defaults 0 2
# swap was on /dev/sda6 during installation
UUID=ef82a317-ac35-4498-a65c-8d6469f4ab7a none swap sw 0 0
=================== sda5: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
======================== Unknown MBRs/Boot Sectors/etc: ========================
Unknown BootLoader on sda4
00000000 33 6f 56 d2 55 04 32 9d 49 e7 21 a5 8c b5 54 45 |3oV.U.2.I.!...TE|
00000010 20 8a 29 57 2f 79 51 6b 15 b9 24 f9 dc 1d 9a 4f | .)W/yQk..$....O|
00000020 d2 58 bf f4 b5 ff d7 a7 9b 3b ae b1 a6 91 e9 ef |.X.......;......|
00000030 c8 d9 7a 59 03 0a 21 44 cd 24 f3 13 12 aa 8e 6e |..zY..!D.$.....n|
00000040 00 1e 8a d2 72 2a dc d9 04 0c 27 e3 d3 2d 5a ff |....r*....'..-Z.|
00000050 f1 ea 00 4e 2a ea 60 6a 01 5f f9 1f 37 a2 94 ad |...N*.`j._..7...|
00000060 be 21 6f ef 3f 7c b5 0a f7 ae 5c 55 07 b8 e5 20 |.!o.?|....\U... |
00000070 dd df 51 94 4b 1f 5a bb f8 51 b1 78 d0 b3 67 12 |..Q.K.Z..Q.x..g.|
00000080 0b fc 8f db 2c 86 8d 42 3a 89 14 89 b6 dc ad 01 |....,..B:.......|
00000090 bc 5a f7 9c c9 ad b4 31 61 7e 57 a4 cd 79 0a 79 |.Z.....1a~W..y.y|
000000a0 ba ce 17 1a 13 60 8d 6d f9 0a df b3 76 d1 06 73 |.....`.m....v..s|
000000b0 f3 19 3a 6b d5 6a 0a cd 5e 93 39 a8 04 b3 cb 8a |..:k.j..^.9.....|
000000c0 a7 9f 54 30 9c 94 e7 c6 ea cf 22 4e d4 a0 a2 37 |..T0......"N...7|
000000d0 6b 4b fd 95 c8 8d 79 04 9a c2 bb a6 22 9c 16 f8 |kK....y....."...|
000000e0 89 18 7e 96 3b 38 e2 ab 30 15 ed 7a a6 1a 1f 73 |..~.;8..0..z...s|
000000f0 2b be 2b e5 37 ce 6d da 23 d4 61 06 89 4c 9f d5 |+.+.7.m.#.a..L..|
00000100 84 58 54 c4 96 74 3e d7 a9 28 7b 20 22 14 3d 60 |.XT..t>..({ ".=`|
00000110 b6 b3 49 d0 4d 06 fc 18 3b e1 9e 21 70 e3 f7 25 |..I.M...;..!p..%|
00000120 57 ca b7 fc 91 6d b8 85 a3 43 9a 11 48 98 50 6b |W....m...C..H.Pk|
00000130 3c 95 5b 67 b2 d5 25 0a 7e 6a 5e c5 88 5f dd 0f |<.[g..%.~j^.._..|
00000140 78 e5 aa 41 22 a4 f8 8e 2d 40 44 c1 98 aa 33 01 |x..A"...-@D...3.|
00000150 7e 6d b5 e5 19 15 51 40 14 16 98 04 b1 84 38 1d |~m....Q@......8.|
00000160 47 e7 be e0 19 a6 d7 e4 c8 5c 91 94 6a 59 9d cf |G........\..jY..|
00000170 41 cc 68 3a 7f 7a 39 ea 27 f5 cc 01 30 72 cf 87 |A.h:.z9.'...0r..|
00000180 00 26 e1 88 a1 88 b6 84 62 ba d3 c8 d5 41 b9 e1 |.&......b....A..|
00000190 72 fd ae 5f 1c 02 65 f5 b8 74 2a 89 cb a2 b1 3f |r.._..e..t*....?|
000001a0 ff f3 20 4f 9a 7c 0f 50 0b f6 7b 1b 08 a8 51 4b |.. O.|.P..{...QK|
000001b0 8e fb 0a 51 84 d2 26 b6 9c 07 56 17 56 4c 00 fe |...Q..&...V.VL..|
000001c0 ff ff 83 fe ff ff 02 00 00 00 00 00 54 02 00 fe |............T...|
000001d0 ff ff 05 fe ff ff 02 00 54 02 00 38 77 00 00 00 |........T..8w...|
000001e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa |..............U.|
00000200
=============================== StdErr Messages: ===============================
cat: /tmp/BootInfo-qpWbVfHM/Tmp_Log: No such file or directory
Asked
Active
Viewed 307 times
-2
Fabby
- 35,017
Biplob Paul
- 1
- 1
Your problem is that Ubuntu (and thus grub) was installed in UEFI mode and Windows 10 was upgraded from a Windows 7 in BIOS mode.
Both boot systems are not compatible with one another and now you need to go into your BIOS settings to choose between legacy mode to boot Win10 and UEFI for Ubuntu.
If this is a fresh install, set your system back to BIOS boot mode and install Ubuntu in BIOS mode too and then Windows will show up in grub automagically. :-)
This also has nothing to do with Ubuntu, so I'll close your question as off topic next.
¯\_(ツ)_/¯
Fabby
- 35,017
