I'm wondering, what is the reccomended way to install LXDE alongside Ubuntu 19.04, while getting the full "Lubuntu" experience? I tried running the following command:
>$ sudo apt install lubuntu-desktop
The following information may help resolve the situation:
 lubuntu-desktop : Depends: ubuntu-release-upgrader-qt but it is not going to be installed
                   Recommends: plasma-discover but it is not going to be installed
I know I can do sudo apt install lxde, but does that give everything that lubuntu-desktop has? Or will it just be a stripped-down default LXDE installation?
I tried doing and apt update and dist-upgrade, but it made no change.
